[Nek5000-users] blending coefficient in 3D
Tue Feb 27 09:13:53 CST 2018
In order to make a smooth blending coefficient for mesh motion, I made a code below, it works fine for a 2D case in my computer but it does not work as expected for a 3D case (I run 3D case in server with 1024 pocessors). Could you please tell me is there anything wrong? (The error is the volume that i am getting is some wrong values i think) and is it right way to make Dirichlet B.C on boundaries also calling hmholtz function to make a blending velocity gradient? Because I took that part from the NEK example which is 2D. So do i have to change anything to make working in 3D?
subroutine my_base_meshv(basev,h1,h2,rhs,msk,tmp)
include 'SIZE'
include 'TOTAL'
real basev(lx1,ly1,lz1,lelt),tmp(lx1,ly1,lz1,lelt)
real h1(1),h2(1),rhs(1),msk(1)
real m1,denom,volume(nx1*ny1*nz1*nelv)
integer e,f
n = nx1*ny1*nz1*nelv
nxyz = nx1*ny1*nz1
do e=1,n
volume(e) = vlsum(bm1(e,1,1,1),nxyz)
enddo
a=glmax(volume,n)
b=glmin(volume,n)
do i=1,n
denom = 1/a
h1(i) = ((1-(b/a))/(denom*volume(i)))
enddo
do i=1,n
open (unit=10,file="h.dat")
write (10,7020) h1(i),volume(i),a,b
7020 format(7f20.8)
enddo
m1 = -1.
z0 = 0.
nface = 2*ndim
do e=1,nelv
do f=1,nface
c Set Dirichlet for mesh velocity on all boundaries
if (cbc(f,e,1).ne.'E ') call facev(msk,e,f,z0,nx1,ny1,nz1)
c Inhomogeneous Dirichlet on cylinder only
if (cbc(f,e,1).eq.'mv ') then
call fcaver(xavg,xm1,e,f)
if (xavg.gt.-1.2) call facev(tmp,e,f,m1,nx1,ny1,nz1)
endif
enddo
enddo
call axhelm (rhs,tmp,h1,h2,1,1)
tol = 1.e-4
imsh = 1
ifield = 1
call hmholtz('mshv',basev,rhs,h1,h2,msk,vmult,imsh,tol,200,1)
call sub2(basev,tmp,n)
c call outpost(basev,basev,basev,basev,basev,' ')
c stop
return
end
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180227/7b65e3c0/attachment.html>
