[Nek5000-users] Volume of an element
Tue Feb 27 06:28:54 CST 2018
Dear Sijo,
The volume per grid point is given by the entries in bm1(i,j,k,e)
For each element e, there are points [i,j,k] with index ranges i=1,...,nx1
j=1,...,ny1, k=1,...,nz1
You must reference elements by the 4th index (...,e).
Fortunately, all the data is contiguous, so, if accessing _all_ points,
you can use a loop like
      do i=1,n
           volume_of_point_i = bm1(i,1,1,1)
      enddo
You certainly do not need to do any summing if you only want the
point wise volume.
Perhaps it'd be best if you indicate what exactly you are planning to
do with the volume.
Finally, I see your use of glmax and glmin.  How many processors
are you using?  If more than one, are you intending that they are
all writing to the file hcoeff.dat?
hth,
Paul
From: Nek5000-users <nek5000-users-bounces at lists.mcs.anl.gov> on behalf of nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
Sent: Tuesday, February 27, 2018 4:45:30 AM
To: nek5000-users
Subject: Re: [Nek5000-users] Volume of an element
Thanks Paul for your Kind replay. You were right. I want to get the volume associated with each grid point.  And I tried the code below, but at each time when I run I get different answers for volume so I think my ocde is not rubust. Could you please verify my code below.
      nxyz = nx1*ny1*nz1
      n = nx1*ny1*nz1*nelv
      vol = vlsum(bm1(1,1,1,1),nxyz)
      a=glmax(vol,1)
      b=glmin(vol,1)
      do e=1,n
         volume = vlsum(bm1(e,1,1,1),nxyz)
         open (unit=10,file="hcoeff.dat")
         write (10,7020) a,b,volume
7020  format(7f20.14)
      enddo
Regards
Sijo GEORGE
De: "nek5000-users" <nek5000-users at lists.mcs.anl.gov>
À: "nek5000-users" <nek5000-users at lists.mcs.anl.gov>
Envoyé: Lundi 26 Février 2018 21:46:02
Objet: Re: [Nek5000-users] Volume of an element
Dear Sijo,
We typically refer to elements as the structures that have (N+1)^3
points.  (Here, N+1 = lx1.)
They are enumerated in nek5000 by the element number, e:
      integer e
      nxyz = nx1*ny1*nz1
      do e=1,nelt
            volume = volel(e)
            volume = vlsum(bm1(1,1,1,e),nxyz)
      enddo
would both yield the same value for the volume of element e.
It appears to me that you are after something different, however.
It seems like you want to associate a volume with each grid point.
If that is the case, then the entries of the diagonal mass matrix, bm1,
are indeed the quantities that you want.
Each entry of bm1(i,1,1,1)  for i=1 to n:=nxyz*nelt, corresponds to the
integral of the underlying basis function.
That is, if we think about a function phi_i(x) such that
             u(x) = sum_i=1^n u(i,1,1,1)*phi_i(x)
then
        bm1(i,1,1,1) = \int phi_i(x) dx
where the integral (\int) is taken over the entire computational domain.
[ Note that we really don't have such a global phi_i(x) ... I use it simply
for illustration, here.]
hth
Paul
Sent: Monday, February 26, 2018 11:59:19 AM
To: nek5000-users
Subject: [Nek5000-users] Volume of an element
Hi Neks,
How to calculate volume of an element in a 3D mesh? If i write
do i=1,n
     v(i) = volume(1,1,1,i)
enddo
Can i store the volume of each element into a varibale called v?
What happens if i use bm1(1,1,1,i)? Instead of volume(1,1,1,i)
Thanks
Sijo
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl.gov
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180227/769f4924/attachment.html>
