[Nek5000-users] Mismatch of X,Y cordinates
Mon Feb 26 07:34:14 CST 2018
Hi Neks,
I was trying to make sure the the moving wall condition has properly applied on .rea file by writing the x and y co -ordinates through the .usr file during the run time to a file called rectangle.dat (element number,face number,x,y respectively). But it looks bit different from what i have i given in .rea file. Esepacially if you check the output data file called rectangle.dat on line 5, the x and y co ordinates are 0.9375,0.9375 corresponding to the 133rd element and 2nd phase. But if we check the .rea file its not showing the right one. I have attached all the necessary files to run this case and could you please tell me what went wrong?
Thanks in advance
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180226/259eec06/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180226/259eec06/attachment-0006.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180226/259eec06/attachment-0007.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180226/259eec06/attachment-0008.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180226/259eec06/attachment-0009.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180226/259eec06/attachment-0010.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180226/259eec06/attachment-0011.obj>
