[Nek5000-users] turbChannel: history points and instantaneous velocity field
Tue Feb 20 13:20:57 CST 2018
Is you case named check? If not it will fail.
On 20 Feb 2018, at 20:18, "nek5000-users at lists.mcs.anl.gov <mailto:nek5000-users at lists.mcs.anl.gov> " <nek5000-users at lists.mcs.anl.gov <mailto:nek5000-users at lists.mcs.anl.gov> > wrote:
Hello,
Could you please be more specific about the “case off-list”? I did not really get it.
The file I used for the hpts() feature is named as “check.his”.
Emily
____________________________________________________
Make sure you file is called <casename>.his
Hi Emily,
Could you send me your case off-list so that I could have a look?
Sincerely,
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl.gov <mailto:Nek5000-users at lists.mcs.anl.gov>
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180220/2ff85323/attachment.html>
