[Nek5000-users] DNS of turbChannel
Fri Feb 9 13:31:25 CST 2018
Hello Paul,
Thank you a lot for your explanation; it really helps. For now, I am using the most recent turChannel example of NEK5000 V.17. I successfully simulated a turbulent channel with a Retau of 180 using 1536 elements (I am aware of it's a lot of elements). The default settings were applied. I wonder is it in the .par file where you do the modification to convert it into DNS? Or somewhere else as well?
Again, thank you for the help,
Emily
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180209/6888cc5c/attachment.html>
