[Nek5000-users] reshape array
Wed Aug 15 09:34:29 CDT 2018
f77 array declarations do either one or two things, depending on
whether the array is passed as an argument or is declared within
the scope of the routine or function in question.
If the array is in a common block or is declared for the first time
within a subroutine/function, then the statement sets aside memory.
For example:
        subroutine blah(z)
        include 'SIZE'
        real x(lx1,ly1,lz1,lelt)
        common /c1/ y(lx1,ly1,lz1,lelt)
        real z(lx1,ly1,lz1,lelt)
        integer e
results in two arrays, x and y, be declared to hold n words of memory,
where n = lx1*ly1*lz1*lelt
The line "real z(...)" does not declare any memory.
All three statements indicate how to reference an entry in any
of the arrays by the formula:
            [ z(i,j,k,e) ] = [z(1,1,1,1)] +
                                  (i+(j-1)*lx1+(k-1)*lx1*ly1+(e-1)*lx1*ly1*lz1)*wdsize
where [.] implies the address of the argument.   This formula applies
equally to x,y, and z in the above example.  f77 does not care about
i,j,k, or e (save that they must be integer).  It assumes you know what
you are doing when you compute an address.   Thus the following are
almost equivalent:
      do e=1,nelt
      do k=1,lz1
      do j=1,ly1
      do i=1,lx1
           x(i,j,k,e)=z(i,j,k,e)
      enddo
      enddo
      enddo
      enddo
      n = lx1*ly1*lz1*nelt   (Note: nelt, not lelt)
      do i=1,n
           x(i,1,1,1) = z(i,1,1,1)
      enddo
The latter, however, is _much_ better than the former.  Why?
Most compilers will not vectorize more than one loop deep (the "i" loop
in the first of the two preceding examples).   You thus have a relatively short loop for vectorization; whereas the second, single-loop, form will vectorize.  Moreover, the second form makes the code much easier to use.   The essential point is that x and z are contiguous arrays --- which is the case throughout nek.
NOTE:  many users are hesitant about using the 2nd form, despite the fact that it is vastly superior to the first.  There is no need to be uneasy about this form, however.  It has been used in Nek for over 30 years on hundreds of the world's fastest computers.  It is a well-know fortran trick for high performance.   Please look through the Nek5000 source for more examples of this type.
From: Nek5000-users <nek5000-users-bounces at lists.mcs.anl.gov> on behalf of nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
Sent: Wednesday, August 15, 2018 4:16:15 AM
To: nek5000-users at lists.mcs.anl.gov
Subject: [Nek5000-users] reshape array
Hi all,
All average streamwise velocity are stored in this array
“common /avg/ uavg(lx1,ly1,lz1,lelv)”
but I want this array to be reshaped into
“common /abcd/ abcd(lx1*ly1*lz1,lelv)”
The following didn’t work:
abcd=reshape(uavg,(/ lx1*ly1*lz1,lelv /))
This is how array reshaping works in fortran. Unfortunately, didn’t work in nek. Anyone knows why?
Many thanks in advance for your replies.
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180815/5e0bf86e/attachment-0001.html>
