[Nek5000-users] Problem on cluster
Mon Apr 16 20:03:00 CDT 2018
Stefan,
Is there a way to run this without the flock option?  For a variety of reasons we don’t support it on our system and I have been trying to run nek but having the same issue.  Are there any compile flags that I can use or a different version of mpi perhaps?  Recommendations welcome.
   Julie
From: Nek5000-users <nek5000-users-bounces at lists.mcs.anl.gov> on behalf of "nek5000-users at lists.mcs.anl.gov" <nek5000-users at lists.mcs.anl.gov>
Reply-To: "nek5000-users at lists.mcs.anl.gov" <nek5000-users at lists.mcs.anl.gov>
Date: Monday, April 16, 2018 at 7:49 PM
Subject: Re: [Nek5000-users] Problem on cluster
Before updating, can you please check if the following advise helps:
If the file system is LUSTRE, ensure that the directory is mounted with the 'flock' option
Stefan
On 16 Apr 2018, at 19:39, "nek5000-users at lists.mcs.anl.gov" <nek5000-users at lists.mcs.anl.gov> wrote:
Please use the release tarball instead of the GitHub master! The error message suggest that your MPI installation is outdated -> some necessary MPIIO features are missing. I think updating MPI will do the trick.
Stefan.
On 16 Apr 2018, at 17:46, "nek5000-users at lists.mcs.anl.gov" <nek5000-users at lists.mcs.anl.gov> wrote:
Dear Nek users, I'm having a problem when I use the latest version of Nek on a HPC cluster. I can compile, but when I run my simulations they finish. The logfile of a generic case is like the following:
|      _   __ ______ __ __  ______  ____   ____   ____     |
|     / | / // ____// //_/ / ____/ / __ \\/ __ \\/ __ \\   |
|    /  |/ // __/  / ,<   /___ \\ / / / // / / // / / /    |
|   / /|  // /___ / /| | ____/ / / /_/ // /_/ // /_/ /     |
|  /_/ |_//_____//_/ |_|/_____/  \\___/ \\___/ \\___/      |
| NEK5000:  Open Source Spectral Element Solver            |
| COPYRIGHT (c) 2008-2017 UCHICAGO ARGONNE, LLC            |
| Version:  17.0-rc1                                       |
| Web:      http://nek5000.mcs.anl.gov                     |
 Number of processors:          80
 REAL    wdsize      :           8
 INTEGER wdsize      :           4
 Timer accuracy      : 0.00E+00
 Reading /home/jrobinson/casos/Placa_6/Placa_6.rea
 Reading /home/jrobinson/casos/Placa_6/Placa_6.re2
 mapping elements to processors
 Reading /home/jrobinson/casos/Placa_6/Placa_6.ma2
 RANK     0 IEG    1754    1755    1756    1757    1758    1759    1760    1774
                   1775    1776    1777    1778    1779    1780    1794    1795
                   1796    1797    1798    1799    1800    1814    1815    1816
                   1817    1818    1819    1820    1834    1835    1836    1837
                   1838    1839    1840    1853    1854    1855    1856    1857
                   1858    1859    1860    1873    1874    1875    1876    1877
                   1878    1879    1880    1893    1894    1895    1896    1897
                   1898    1899    1913    1914    1915    1916    1917    1918
                   1919    1933    1934    1935    1936    1937    1938    1939
                   1953    1954    1955    1956    1957    1958    1974    1975
                   1976    1977    1978    1994    1995    1996    1997    1998
                   1999    2000    2014    2015    2016    2017    2018    2019
                   2020    9783    9784    9785    9786    9787    9788    9789
                   9790    9791    9792    9793    9794    9795    9796    9797
                   9798    9799    9800    9801    9802    9803    9804    9805
                   9806    9807    9808    9809    9810    9811    9812    9813
                   9814    9815    9816    9817    9818    9819    9820    9821
                   9822    9823    9824    9825    9826    9827    9828    9829
                   9830    9849    9855    9856    9861    9862
 element load imbalance:            1         150         151
 done :: mapping   0.32155     sec
  preading mesh
So the last line is "preading mesh".
This doesn't give too much information, but the cluster generates a file with the following errors (at the end of this text).
When I use an old version of Nek on this same cluster, I have no problem running my cases. The problem is that I need to use the latest version because I'm using exo2nek routine for my meshes generated with Trelis (Cubit).
Any idea of what could I do?
Thank you all.
Juan Pablo.
This requires fcntl(2) to be implemented. As of 8/25/2011 it is not. Generic MPICH Message: File locking failed in ADIOI_Set_lock(fd 4A,cmd F_SETLKW/7,type F_RDLCK/0,whence 0) with return value FFFFFFFF and errno 26.
- If the file system is NFS, you need to use NFS version 3, ensure that the lockd daemon is running on all the machines, and mount the directory with the 'noac' option (no attribute caching).
- If the file system is LUSTRE, ensure that the directory is mounted with the 'flock' option.
ADIOI_Set_lock:: Function not implemented
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl.gov
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180417/8f078128/attachment-0001.html>
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180417/8f078128/attachment-0001.p7s>
