[Nek5000-users] Problem on cluster
Mon Apr 16 16:45:41 CDT 2018
Dear Nek users, I'm having a problem when I use the latest version of Nek
on a HPC cluster. I can compile, but when I run my simulations they finish.
The logfile of a generic case is like the following:
|      _   __ ______ __ __  ______  ____   ____   ____     |
|     / | / // ____// //_/ / ____/ / __ \\/ __ \\/ __ \\   |
|    /  |/ // __/  / ,<   /___ \\ / / / // / / // / / /    |
|   / /|  // /___ / /| | ____/ / / /_/ // /_/ // /_/ /     |
|  /_/ |_//_____//_/ |_|/_____/  \\___/ \\___/ \\___/      |
| NEK5000:  Open Source Spectral Element Solver            |
| COPYRIGHT (c) 2008-2017 UCHICAGO ARGONNE, LLC            |
| Version:  17.0-rc1                                       |
| Web:      http://nek5000.mcs.anl.gov                     |
 Number of processors:          80
 REAL    wdsize      :           8
 INTEGER wdsize      :           4
 Timer accuracy      : 0.00E+00
 Reading /home/jrobinson/casos/Placa_6/Placa_6.rea
 Reading /home/jrobinson/casos/Placa_6/Placa_6.re2
 mapping elements to processors
 Reading /home/jrobinson/casos/Placa_6/Placa_6.ma2
 RANK     0 IEG    1754    1755    1756    1757    1758    1759    1760
1774
                   1775    1776    1777    1778    1779    1780    1794
1795
                   1796    1797    1798    1799    1800    1814    1815
1816
                   1817    1818    1819    1820    1834    1835    1836
1837
                   1838    1839    1840    1853    1854    1855    1856
1857
                   1858    1859    1860    1873    1874    1875    1876
1877
                   1878    1879    1880    1893    1894    1895    1896
1897
                   1898    1899    1913    1914    1915    1916    1917
1918
                   1919    1933    1934    1935    1936    1937    1938
1939
                   1953    1954    1955    1956    1957    1958    1974
1975
                   1976    1977    1978    1994    1995    1996    1997
                   1999    2000    2014    2015    2016    2017    2018
                   2020    9783    9784    9785    9786    9787    9788
9789
                   9790    9791    9792    9793    9794    9795    9796
9797
                   9798    9799    9800    9801    9802    9803    9804
9805
                   9806    9807    9808    9809    9810    9811    9812
9813
                   9814    9815    9816    9817    9818    9819    9820
9821
                   9822    9823    9824    9825    9826    9827    9828
9829
                   9830    9849    9855    9856    9861    9862
 element load imbalance:            1         150         151
 done :: mapping   0.32155     sec
  preading mesh
So the last line is "preading mesh".
This doesn't give too much information, but the cluster generates a file
with the following errors (at the end of this text).
When I use an old version of Nek on this same cluster, I have no problem
running my cases. The problem is that I need to use the latest version
because I'm using exo2nek routine for my meshes generated with Trelis
(Cubit).
Any idea of what could I do?
Thank you all.
Juan Pablo.
This requires fcntl(2) to be implemented. As of 8/25/2011 it is not.
Generic MPICH Message: File locking failed in ADIOI_Set_lock(fd 4A,cmd
F_SETLKW/7,type F_RDLCK/0,whence 0) with return value FFFFFFFF and errno 26.
- If the file system is NFS, you need to use NFS version 3, ensure that the
lockd daemon is running on all the machines, and mount the directory with
the 'noac' option (no attribute caching).
- If the file system is LUSTRE, ensure that the directory is mounted with
the 'flock' option.
ADIOI_Set_lock:: Function not implemented
ADIOI_Set_lock:offset 84, length 10800
Generic MPICH Message: File locking failed in ADIOI_Set_lock(fd 11,cmd
the 'flock' option.
ADIOI_Set_lock:offset 32484, length 10800
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 3
In: PMI_Abort(1, application called MPI_Abort(MPI_COMM_WORLD, 1) - process
3)
the 'flock' option.
Generic MPICH Message: File locking failed in ADIOI_Set_lock(fd F,cmd
the 'flock' option.
ADIOI_Set_lock:offset 86484, length 10800
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 8
8)
Generic MPICH Message: File locking failed in ADIOI_Set_lock(fd 14,cmd
the 'flock' option.
ADIOI_Set_lock:offset 248484, length 10800
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 23
23)
the 'flock' option.
ADIOI_Set_lock:offset 108084, length 10800
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 10
10)
Generic MPICH Message: File locking failed in ADIOI_Set_lock(fd 10,cmd
the 'flock' option.
ADIOI_Set_lock:offset 259284, length 10800
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 24
24)
Generic MPICH Message: File locking failed in ADIOI_Set_lock(fd 12,cmd
the 'flock' option.
ADIOI_Set_lock:offset 118884, length 10800
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 11
11)
the 'flock' option.
the 'flock' option.
ADIOI_Set_lock:offset 140484, length 10800
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 13
13)
the 'flock' option.
ADIOI_Set_lock:offset 280884, length 10800
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 26
26)
the 'flock' option.
ADIOI_Set_lock:offset 151284, length 10800
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 14
14)
the 'flock' option.
ADIOI_Set_lock:offset 291684, length 10800
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 27
27)
the 'flock' option.
ADIOI_Set_lock:offset 162084, length 10800
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 15
15)
the 'flock' option.
ADIOI_Set_lock:offset 302484, length 10800
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 28
28)
the 'flock' option.
ADIOI_Set_lock:offset 172884, length 10800
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 16
16)
the 'flock' option.
ADIOI_Set_lock:offset 324084, length 10800
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 30
30)
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 0
0)
Generic MPICH Message: File locking failed in ADIOI_Set_lock(fd 13,cmd
the 'flock' option.
ADIOI_Set_lock:offset 334884, length 10800
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 31
31)
the 'flock' option.
ADIOI_Set_lock:offset 21684, length 10800
2)
the 'flock' option.
ADIOI_Set_lock:offset 345684, length 10800
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 32
32)
the 'flock' option.
ADIOI_Set_lock:offset 43284, length 10800
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 4
4)
the 'flock' option.
ADIOI_Set_lock:offset 356484, length 10800
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 33
33)
the 'flock' option.
ADIOI_Set_lock:offset 54084, length 10800
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 5
5)
the 'flock' option.
ADIOI_Set_lock:offset 367284, length 10800
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 34
34)
the 'flock' option.
ADIOI_Set_lock:offset 64884, length 10800
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 6
6)
the 'flock' option.
ADIOI_Set_lock:offset 378084, length 10800
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 35
35)
the 'flock' option.
ADIOI_Set_lock:offset 75684, length 10800
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 7
7)
the 'flock' option.
ADIOI_Set_lock:offset 388884, length 10800
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 36
36)
the 'flock' option.
ADIOI_Set_lock:offset 97284, length 10800
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 9
9)
the 'flock' option.
ADIOI_Set_lock:offset 421284, length 10800
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 39
39)
the 'flock' option.
ADIOI_Set_lock:offset 129684, length 10800
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 12
12)
ADIOI_Set_lock:offset 216084, length 10800
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 20
20)
the 'flock' option.
ADIOI_Set_lock:offset 183684, length 10800
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 17
17)
the 'flock' option.
ADIOI_Set_lock:offset 226884, length 10800
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 21
21)
the 'flock' option.
ADIOI_Set_lock:offset 194484, length 10800
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 18
18)
the 'flock' option.
ADIOI_Set_lock:offset 237684, length 10800
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 22
22)
the 'flock' option.
ADIOI_Set_lock:offset 205284, length 10800
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 19
19)
the 'flock' option.
ADIOI_Set_lock:offset 313284, length 10800
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 29
29)
the 'flock' option.
ADIOI_Set_lock:offset 10884, length 10800
the 'flock' option.
ADIOI_Set_lock:offset 399684, length 10800
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 37
37)
1)
the 'flock' option.
ADIOI_Set_lock:offset 410484, length 10800
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 38
38)
slurmstepd: error: *** STEP 11073373.0 ON leftraru1 CANCELLED AT
2018-04-16T18:38:42 ***
ADIOI_Set_lock:offset 270084, length 10800
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 25
25)
srun: Job step aborted: Waiting up to 32 seconds for job step to finish.
srun: error: leftraru1: tasks 0-19: Killed
srun: Terminating job step 11073373.0
srun: error: leftraru4: tasks 60-79: Killed
srun: error: leftraru3: tasks 40-59: Killed
srun: error: leftraru2: tasks 20-39: Killed
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180416/3da75c9d/attachment-0001.html>
