[Nek5000-users] Change boundary condition type with time?
Fri Apr 13 01:29:39 CDT 2018
Thank you Nicolas and Paul,
I think I understand your suggestion Paul about changing the BC:s in the way Nicolas suggests in usrdat2.
But in practice I dont know how to implement the Boolean "face belongs to part B".
Is this done using cbc(ifc,iel,ifld)=='v  '?
Paul: Yes, I was planning to have an inflow through an open bounday. I was not aware of that this may imply instabilities.
I want to simulate a flow resembling a "smoke ring" (vortex ring puffed out bya cigarette smoker). What BC:s would you suggest?
I could imagine that Dirichlet BC:s that change with time could work ...
Best,
Johan
From: Nek5000-users <nek5000-users-bounces at lists.mcs.anl.gov> on behalf of nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
Sent: Thursday, April 12, 2018 1:15:06 PM
To: nek5000-users at lists.mcs.anl.gov
Subject: Re: [Nek5000-users] Change boundary condition type with time?
Dear Johan,
I guess I'm confused about the "open boundary" part of your request.
Do you anticipate flow leaving through this part? Or no flow coming in?
The reason I ask is that it's generally unstable to have any flow coming into
the domain through an open boundary.
Aside from that, there are some technical issues to deal with.  You need to
change the boundary conditions, as Nicolas pointed out, but you also need to
recompute the preconditioners that are set up at the beginning of the computation
because they depend on the type of BC that is employed.
I think the easiest and best approach would be to evolve your initial condition to
the point where you want to change the BC and then stop the calculation and
use the second BC option from that point (i.e., by using a different rea file for
the second part of the computation, or by applying Nicolas's suggestion in
subroutine usrdat2, which is called before the preconditioners are established).
Note that you can have your inflow BC be time dependent -- flow turned, then flow
turned off -- which is all Dirichlet, and you don't need to start/stop the calculation.
hth
Paul
Sent: Wednesday, April 11, 2018 7:08:12 AM
Subject: [Nek5000-users] Change boundary condition type with time?
Hi Neks,
I wonder if it is possible to have boundary conditions that chage type with time?
I want to simulate a flow where I make a 'puff' of fluid through a hole in a wall.
After the puff is made it continues to evolve without beeing forced.
Mathematically, this is what I want:
  1.  Dirichlet boundary conditions (ux,uy,uz) = (0,0,1) for the velocity at a part B of the boundary up to a time T.
  2.  Open boundary condition for the velocity at B for time > T.
Is this possible to implement?
Best,
Johan
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180413/df7db06d/attachment.html>
