[Nek5000-users] Simulation hanging at 'mapping elements to processors'
Thu Sep 28 09:16:50 CDT 2017
I submitted the job to the queue with the same number of processors as before. I will keep you updated.
While it is running, I have a question on the moving boundary capability. With the latest version of Nek5000, the mesh dumped in the output files does not move over time even though the solution looks good. In the previous version I run, I set ifxyo to true to write the mesh in the output file. I could not find the reason why the mesh is not updated in the output file in the latest version even by looking at the examples.
Does anyone know how to dump the mesh in the output files along with the solution?
Marco
> On Sep 27, 2017, at 4:43 AM, nek5000-users at lists.mcs.anl.gov wrote:
> Yes but this on a different number of ranks. It would be better to rerun the same case (same lelt, np, ...) which failed the first time.
> Stefan
> -----Original message-----
>> From:nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
>> Sent: Wednesday 27th September 2017 6:04
>> To: nek5000-users at lists.mcs.anl.gov
>> Subject: Re: [Nek5000-users] Simulation hanging at 'mapping elements to processors'
>> I rerun my case with a map file that I generated with a previous version of Nek5000. I run fine with the AMG preconditioner. I attached the log file.
>> Marco
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
