[Nek5000-users] Warning : DIV(V)-QTL too large
Thu Sep 21 08:43:01 CDT 2017
Samuel,
there is one example that uses the low mach formulation in Nek5000: lowMach_test in the short_test directory.
Marco
> On Sep 21, 2017, at 9:39 AM, nek5000-users at lists.mcs.anl.gov wrote:
> Hi,
> As proposed by Stefan, I'm trying to use the PnPn LowMach configuration.
> To do that, I simply set the logical switch of IFLOMACH to "true". But it is not working.
> Could you please explain me, what other parameters I have to change to switch from a PnPn Boussinesq configuration to a PnPn LowMach one ?
> Thank you in advance,
> Samuel
> Nek5000-users mailing list
