[Nek5000-users] Newbie question
Sat Sep 9 06:42:22 CDT 2017
This feature is also called NekNek running two (at least for now) separate (but coupled) Nek5000 instances. Unfortunately all this is still experimental and not well documented. You'll  find an example in the Nek5000 source (short-tests/eddy_neknek). Currently there is no nDOF body motion solver.
Hope this helps,
Stefan
On 8 Sep 2017, at 18:38, "nek5000-users at lists.mcs.anl.gov <mailto:nek5000-users at lists.mcs.anl.gov> " <nek5000-users at lists.mcs.anl.gov <mailto:nek5000-users at lists.mcs.anl.gov> > wrote:
Hello:
I am strongly considering trying out Nek5000 based on some recent research needs.
I want/need the overset meshing capability that appears in the code’s banner page but I do not see any documentation for this.
Specific needs would be to use overset meshing for several bodies moving within a static background atmosphere.
Also would need to implement or apply an nDOF capability for these bodies, although don’t need to consider collisions.
Can anyone point me in the right direction?
Thank you!!
Rob
Robert F Kunz
Professor of Mechanical Engineering
The Pennsylvania State University
301 C Reber Building
University Park, PA 16802
rfk102 at engr.psu.edu <mailto:rfk102 at engr.psu.edu>
814-360-1901
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl.gov <mailto:Nek5000-users at lists.mcs.anl.gov>
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20170909/03eb78f2/attachment.html>
