[Nek5000-users] Restarting with Periodic boundary Condition
Tue Oct 24 16:43:44 CDT 2017
Hello Neks,
I have a small (4x4x1) cubic domain, which is periodic in Y. No slip
boundaries in X and Z. This is to generate a Rayleigh Benard convection
flowfield with Z being the convective direction. The flow is driven by hot
sidewalls in X.
My problem is when I restart the flowfiled from a particular flowfiled file
using the same .rea, .usr files and everything, the periodicity in the Y
direction seems to be gone.
My originial flowfileds are periodic in Y and have the same value of
Velocity Magnitude through all the Y slices ( as can be seen with VisIt).
But my restarted files have different values of velocity magnitude in
different slices of Y, which should not be the case.
This seems to suggest something going wrong during restarting for the
periodic bc side. I haven't noticed any change in the Velocity if I have
no-slip in Y instead of Periodic.
I would appreciate any input on this problem.
Saikat
Saikat Mukherjee,
PhD Student,
Paul Research Group - http://www.me.vt.edu/mpaul/
Engineering Science and Mechanics,
Virginia Tech.
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20171024/a6fd52f9/attachment.html>
