[Nek5000-users] Error when loading file
Fri Oct 20 10:25:30 CDT 2017
This solved the problem, thank you!
By the way: Is is OK to load files from outside the current directory using the full path to the file?
Best,
Johan
From: Nek5000-users <nek5000-users-bounces at lists.mcs.anl.gov> on behalf of nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
Sent: Friday, October 20, 2017 5:06:43 PM
To: nek5000-users at lists.mcs.anl.gov
Subject: Re: [Nek5000-users] Error when loading file
Hi Johan,
There's also an example in navier5.f in the subroutine autoaverager().
Usage is (say):
ls -C1 case0.f* > list.in
then add this to a blank .usr file and run it
c-----------------------------------------------------------------------
      subroutine usrdat2  ! This routine to modify mesh coordinates
      include 'SIZE'
      include 'TOTAL'
      character*127 fname127
      call blank(fname127,127)
      fname127='list.in'
      call auto_averager(fname127) ! simple average of files
      call outpost(vx,vy,vz,pr,t,'   ')
      call exitti('quit after autoaverager$',nelv)
      return
      end
Paul
Sent: Friday, October 20, 2017 9:19:42 AM
load_fld() expects a character*132 on input!
Cheers,
Stefan
-----Original message-----
> From:nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
> Sent: Friday 20th October 2017 16:11
> Subject: [Nek5000-users] Error when loading file
> Hi,
> I load a file in userchk for postprocessing like this:
>       subroutine userchk
>       include 'SIZE'
>       include 'TOTAL'
>       character(64)::filen
>       filen="cha0.f00027"
>       call load_fld(trim(filen))
>       return
>       end
> However, I the program crashes. This is how it looks in the logfile:
>  nsteps=0 -> skip time loop
>  running solver in post processing mode
>  call userchk
>  set initial conditions
>  Checking restart options: cha0.f000274^@^@^@^@start
>  nekuic (1) for ifld            1
>  nekuic (1) for ifld            2
>  nekuic (1) for ifld            3
>  nekuic (1) for ifld            4
>  Reading checkpoint data
>        0       0 OPEN: cha0.f000274^@^@^@^@start
> cha0.f000274
> byte_read() :: fopen failure2!
> ERROR: Error reading restart header in mfi_prepare  ierr=  1
> Why does this error appear, and how can Ifix it?
> Best,
> Johan
> Nek5000-users mailing list
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20171020/7dfd4283/attachment-0001.html>
