[Nek5000-users] Calling subroutine "hpts" for several files
Mon Oct 16 07:26:20 CDT 2017
Dear Johan,
I would look at the hemi example.
There it shows how to interpolate a list of values
(interp_v is a routine inside hemi.usr).
Once you have a list, you can write it out yourself
(again, as shown in hemi.usr).
Make certain that your interrogation list is _not_ repeated
on every processor. (Otherwise you end up doing P times
more work.)
hth,
Paul
From: Nek5000-users <nek5000-users-bounces at lists.mcs.anl.gov> on behalf of nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
Sent: Monday, October 16, 2017 4:04:02 AM
To: nek5000-users at lists.mcs.anl.gov
Subject: [Nek5000-users] Calling subroutine "hpts" for several files
Dear Neks,
I am post processing my data using the subroutine "hpts" to extract field values at specific points.
I want to loop over many files and extract the field values for each file.
Therefore I want to rename the file "hpts.out" that is created everytime I call hpts.
This code snippet is in userchk, and is looks like this:
      do i=1,100
        write(fname,'(I0.5)') i
        fname='cav0.f'//trim(fname)
        call load_fld(fname)
        call hpts
        call nekgsync
        if(nid==0)then
          call rename('hpts.out',trim(fname)//'_hpts')
        endif
        call nekgsync
      enddo
My basename is "cav", so fname is "cav0.f00XXX" for XXX = 1, ..., 100.
The code is intended to rename hpts.out for a file "cav0.f00XXX" into "cav0.f00XXX_hpts".
However, this does not work.
I get only one file; "cav0.f00001_hpts".
When I open this file it contains the data from "cav0.f000100 - the last file that was opened in the loop!
This makes me wonder if hpts.out is properly closed after beeing written to?
And also, how can I change my code to make it work as I indended?
Best,
Johan
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20171016/ff649135/attachment.html>
