[Nek5000-users] Interpolation in uservp
Wed Oct 11 12:30:25 CDT 2017
Hello Juan,
take a look at the hemi example and its use of the interp_v subroutine for the velocity. I assume this also works for the temperature field.
Jan
> Am 11.10.2017 um 19:26 schrieb nek5000-users at lists.mcs.anl.gov:
> Hi,
> I need run a simulation with a variable param(2) in time. I'd like to have several probing or history points in the temperature field, and every time step calculate the average value in time of each of those points. When these values are stable I increase param(2) in uservp, and repeat the procedure.
> So my question is, how can I obtain the temperature value at a certain (x,y,z) point every time step so I can store it and calculate the average so far at that time?
> Thank you,
> Juan Pablo.
> Nek5000-users mailing list
