[Nek5000-users] Failing to converge when running in parallel
Wed Nov 29 12:14:31 CST 2017
When running with mpi, I am currently experiencing an error with helmholtz which causes the solution to blow up quickly. The issue seems to disappear when running on lower mpi ranks. Is there a known issue which may cause this, or a work around I can employ? I haven't seen this before for similar mesh sizes. This case is a small mesh, but I plan on upscaling quite a bit. See attached for the run log and user file.
Jefferson Davis
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20171129/c17899f1/attachment-0001.html>
Type: text/x-log
Desc: run.log
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20171129/c17899f1/attachment-0001.bin>
Desc: turbChannel.usr
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20171129/c17899f1/attachment-0001.obj>
