[Nek5000-users] Conjugate Problem
Wed Nov 29 03:40:20 CST 2017
There is example in NekExample repository called conj_ht. You can take a
look at it.
Regards
Adam
On 28/11/17 20:20, nek5000-users at lists.mcs.anl.gov wrote:
> Hello, Paul
> Thank you. This is helpful. Is there any document that discuss the
> detail about the algorithm of conjugate problem in Nek5000. We can
> read and reference this document.
> Mu Xu
> On Mon, Nov 27, 2017 at 3:55 PM, <nek5000-users at lists.mcs.anl.gov
> <mailto:nek5000-users at lists.mcs.anl.gov>> wrote:
>     Dear Mu,
>     The best way to think of  CHT is as if solving an
>     advection-diffusion equation with u==0 in the solid.
>     In Nek5000, the fluid elements are numbered first (both globally,
>     and on each processor) so that an fluid/pressure updates are
>     performed on elements e=1,...,nelv; while thermal updates are
>     performed on elements e=1,...,nelt > nelv.
>     Your mesh must be build such that all solid elements are numbered
>     after all fluid elements.
>     hth,
>     Paul
>     *From:* Nek5000-users <nek5000-users-bounces at lists.mcs.anl.gov
>     <mailto:nek5000-users-bounces at lists.mcs.anl.gov>> on behalf of
>     *Sent:* Monday, November 27, 2017 12:11:24 PM
>     *To:* nek5000-users at lists.mcs.anl.gov
>     *Subject:* [Nek5000-users] Conjugate Problem
>     Hello Neks,
>     I am working on a conjugate problem with Nek5000. Is there any
>     reference that discusses how
>     nek5000 solves the conjugate heat transfer problem?
>     Thanks.
>     Mu Xu
>     _______________________________________________
>     Nek5000-users mailing list
>     Nek5000-users at lists.mcs.anl.gov
>     <mailto:Nek5000-users at lists.mcs.anl.gov>
>     https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>     <https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users>
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20171129/06c84d51/attachment.html>
