[Nek5000-users] All elements deformed :: regenerate geometry data
Tue Nov 28 11:27:29 CST 2017
   I have prepared a 3D mesh in GAMBIT and used the matlab converter to
make the .rea
and .map file. When I use these files for computation, things appear to
go on nicely and
the flow field that I get is not different from what I expect. However,
I notice the following
lines in the output file which says that the geometry has been
regenerated. What does
this mean? Would it comprise the quality of the mesh near the wall?
  Reading checkpoint data
  byte swap: F   6.543210     -2.9312772E+35
        FILE:
  restart.f00001
         0  2.7300E+02 done :: Read checkpoint data
                               avg data-throughput = 137.8MBps
                               io-nodes =  1736
  xyz min    -3.5000       0.0000      -10.000
  uvwpt min  -1.5151      -1.7105      -1.6631 -0.87366       0.0000
  PS min      0.0000      0.99000E+22
  xyz max     60.000       3.1200       10.000
  uvwpt max   2.2376      0.91592       1.7789 0.47959       0.0000
  PS max      0.0000     -0.99000E+22
  Restart: recompute geom. factors.
  regenerate geometry data           1
  NOTE: All elements deformed , param(59) ^=0
  done :: regenerate geometry data           1
  done :: set initial conditions
  call userchk
Many thanks,
NN.
