[Nek5000-users] mesh deformation
Mon Nov 27 08:47:35 CST 2017
Dear Sijo,
In the ocyl2 case, the delta is based on a dimension that
is related to the model.  (Here, delta=2*D, where D=1 is
the diameter of the cylinder.)
Such a choice would be reasonable for all flow past a cylinder
cases for that particular geometry, independent of the mesh
resolution.
The boundary-layer thickness criterion is important when there
are multiple objects that are potentially touching.
Keep in mind that any of these choices are moderated by the
fact that we are simply computing a blending function that is
the solution to the (modified) Laplace equation.  It will have
more or less the correct shape --- even the unmodified Laplace
solution is not a terrible blending function.   The modification is
designed simply to help preserve mesh sizes near boundaries.
I paste below a snippet of code that computes the average
thickness of elements near the moving wall.
Paul
         integer e,f
         nxz   = nx1*nz1
         nxyz  = nx1*ny1*nz1
         n     = nxyz*nelv
         srfbl = 0.   ! Surface area of elements in b.l.
         volbl = 0.   ! Volume of elements in boundary layer
         do e=1,nelv
         do f=1,nface
            if (cbc(f,e,1).eq.'mv ') then
               srfbl = srfbl + vlsum(area(1,1,f,e),nxz )
               volbl = volbl + vlsum(bm1 (1,1,1,e),nxyz)
            endif
         enddo
         enddo
         srfbl = glsum(srfbl,1)  ! Sum over all processors
         volbl = glsum(volbl,1)
         delta = volbl / srfbl   ! Avg thickness of b.l. elements
         call rone (h1,n)
         call rzero(h2,n)
         call cheap_dist(d,1,'mv ')
         deltap = 2*delta  ! Protected b.l. thickness
         do i=1,n
            arg   = -(d(i)/deltap)**2
            h1(i) = h1(i) + 9*exp(arg)
         enddo
From: Nek5000-users <nek5000-users-bounces at lists.mcs.anl.gov> on behalf of nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
Sent: Monday, November 27, 2017 7:52 AM
To: nek5000-users
Subject: [Nek5000-users] mesh deformation
Hello Nek,
 I was trying to validate moving cylinder test cases (ocyl2.usr more specifically). I could validate it properly. Even though I have some doubts regarding the mesh motion. Mesh deformation more precisely. I have seen a function to send the deformation to far field apart from the near wall region (Laplace equation with h1 as blending coefficient).So in order to find h1 in the equation there is a parameter called delta (which is 2 in this case). I have also read a paper regarding this equation. In that paper its clearly states that it is the average thickness of the element which is close to the object. So my question is, is there anyway to calculate it automatically or easily to calculate the thickness of that particular elements from any input files? because if I change the mesh (suppose if I refine the mesh size everything will change right?) how can I find the new average thickness of the elements which is close to the object? or how can I measure the area or volume of the elements which is close to the wall. so could you please help me with this?
Thanks with regards
Sijo George
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20171127/707eeb75/attachment.html>
