[Nek5000-users] link between local and global direction
Sat Nov 25 23:11:52 CST 2017
Hi Vatslav,
There is some discussion of mesh deformation here:
http://nek5000.github.io/NekDoc/geometry.html
Look for mesh modification.
As long as your transformation is a relatively smooth
function of the input geometry, i.e., X' = f(X), where
X=(x,y,z) is the input geometry and X'=(x',y',z') is the
output geometry, then things are likely to be ok.
A call to fix_geom just before the "return" statement
in usrdat2 is often a good idea.  That is:
      subroutine usrdat2
      your code here (e.g., following the url above)
      call fix_geom
      return
      end
Note that the comments about outputting the geometry
in the URL above are somewhat dated.   Nek5000 always
writes the geometry to the first 0.f00001 file, so you don't
have to explicitly request to have the geometry written with
the other fields (velocity, pressure, temperature...)
hth,
Paul
From: Nek5000-users <nek5000-users-bounces at lists.mcs.anl.gov> on behalf of nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
Sent: Saturday, November 25, 2017 4:04:02 AM
To: nek5000-users at lists.mcs.anl.gov
Subject: [Nek5000-users] link between local and global direction
Hi, Neks!
What is the principle of creation of link between local ( i, j, k ) in some spectral element and the global coordinate system ( x, y, z ) in sophisticated geometry ?
And how to find out how does these links changes when I move or rotate the elements ?
Regards, Vatslav.
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20171126/50c1224c/attachment.html>
