[Nek5000-users] Storing dragy coefficient
Fri Nov 24 10:18:31 CST 2017
It worked. And now I just have one more question. I store the drag coefficient in each time step
lets say
real dragycoeff(NSTEP)
save dragycoeff
dragycoeff(istep) = dragy(1)
The reason why I store these values : I would like to use them for adams bashforth scheme. (Since I am working on FSI problem and to solve equation of motion) so i may need the previous for 4 values maximum to compute the displacement and velocity values for the next time step.
So my question is, If I have a very large time steps (lets say 500000) will it be efficient? I am also thingking another way like dynamic memory allocation. Since I just need the previous 4 values at each time step, I dont have to store all the drag coefficient for all the time steps. So is there any way in NEK5000 to store the just 4 previous values and update these values at every time step. So that i can decalare a varibale of just siwe of 4 (lets say : real dragycoeff(4) ). Or Can I make any function for that?
Thanks in advance
SIjo GEORGE
De: "nek5000-users" <nek5000-users at lists.mcs.anl.gov>
À: "nek5000-users" <nek5000-users at lists.mcs.anl.gov>
Envoyé: Mercredi 22 Novembre 2017 17:22:30
Objet: Re: [Nek5000-users] Storing dragy coefficient
Thanks Marco I give a try, I am trying to implement FSI with adams bashforth method. RK4 scheme is validated. Now I am doing the stability study (comparing adams and RK4). So thanks and please do keep in touch.
Sijo
Envoyé: Mercredi 22 Novembre 2017 17:18:24
I think it should do the trick.
If you want to use the values in a different subroutine, you must use common block. If the values are used in the same subroutine as they are stored, then save data should be sufficient.
Marco
On Nov 22, 2017, at 11:10 AM, [ mailto:nek5000-users at lists.mcs.anl.gov |
nek5000-users at lists.mcs.anl.gov ] wrote:
Thank you marco.
So you mean if my problem is for 100 time steps and if i declare a variable like below
real dum(100)
save dum
and if i write
dum(istep)= dragy(1) # I have one object
I could store all the dragy coefficient into this array permenently?
Because I just want to use the previous values that means (dum(istep-1)) in some other functions.
Thanks with regards
Sijo GEORGE
De: "nek5000-users" < [ mailto:nek5000-users at lists.mcs.anl.gov | nek5000-users at lists.mcs.anl.gov ] >
À: "nek5000-users" < [ mailto:nek5000-users at lists.mcs.anl.gov | nek5000-users at lists.mcs.anl.gov ] >
Envoyé: Mercredi 22 Novembre 2017 16:58:15
if I correctly understand your problem, you will need to look into common block or save data that are Fortran capabilities.
Marco
BQ_BEGIN
On Nov 22, 2017, at 10:49 AM, [ mailto:nek5000-users at lists.mcs.anl.gov |
I was working on storing dragy coefficient on an array. But its not getting permanently stored in the varibale after the next time step. That means I could not access the previous stored value from the array. Is there any way to store and access dragy of different time steps?
Thanks
with regards
Sijo GEORGE
Nek5000-users mailing list
[ mailto:Nek5000-users at lists.mcs.anl.gov | Nek5000-users at lists.mcs.anl.gov ]
[ https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users | https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users ]
BQ_END
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20171124/9a6222b0/attachment-0001.html>
