[Nek5000-users] Error while compiling exo2nek
Tue Nov 21 08:45:10 CST 2017
> env: ‘./install’: Permission denied
Looks like you cannot run the install. Can you check the permissions.
-----Original message-----
> From:nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
> Sent: Tuesday 21st November 2017 15:38
> To: nek5000-users at lists.mcs.anl.gov
> Subject: Re: [Nek5000-users] Error while compiling exo2nek
> Hi Marco,
> I cant get exo2nek to compile properly at all. After downloading the latest version I get the following error messages when I run sudo ./maketools exo2nek
> Make exo2nek...
> make[1]: Entering directory /home/adutta/Nek5000/tools/exo2nek
> make[1]: Warning: File makefile has modification time 17453 s in the future
> makefile:19: recipe for target lib failed
> make[1]: *** [lib] Error 126
> make[1]: Leaving directory /home/adutta/Nek5000/tools/exo2nek
> ERROR: exo2nek failed to compile!
> makefile:4: recipe for target all failed
> make: *** [all] Error 1
> On Tue, Nov 21, 2017 at 9:33 AM <nek5000-users at lists.mcs.anl.gov <mailto:nek5000-users at lists.mcs.anl.gov>> wrote:
> Can you try the exo2nek script on the attached exo mesh file and see if it works. It works on my machine. It has 2496 elements and 3 sidesets.
> Marco
> Nek5000-users mailing list
> Nek5000-users at lists.mcs.anl.gov <mailto:Nek5000-users at lists.mcs.anl.gov>
> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users <https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users>
> Amitvikram Dutta
> Graduate Research Assistant
> Fluid Mechanics Research Lab
> University of Waterloo
