[Nek5000-users] Problem with drag coefficient of ext_cyl
Wed Nov 8 06:35:42 CST 2017
Hello,
 I just started my PhD work in FSI of NACA profile so I am using NEK5000
for the simulations. So, in order to start with NEK5000, first I try to
validate a very simple test case which is the flow around a 2D cylinder.
This test case is already in the example folder of the solver kit. So, I
try to simply run the test case and tried to compare the drag coefficient
with the given Re number. It was giving a wrong value. for example it gives
21 instead of 3.5 for Re 100.  I had changed the domain a bit according the
research papper I have. I used torque calc function to compute the drag.
Could you please help me to validate this test case? So that I can continue
with lmy moving cylinder test case and I will be more confident in NEK5000
Thanks
SIjo George
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20171108/9ec9dc54/attachment.html>
