[Nek5000-users] Compilation problem on Blue Gene
Mon May 22 06:54:36 CDT 2017
Thanks for the follow-up of my query. Please find attached the compiler.out
file with this mail.
NN.
On Monday 22 May 2017 12:17 PM, nek5000-users at lists.mcs.anl.gov wrote:
> Please post the output of makenek (compile.out)
> On 22 May 2017, at 11:59, "nek5000-users at lists.mcs.anl.gov
> <mailto:nek5000-users at lists.mcs.anl.gov>"
> <nek5000-users at lists.mcs.anl.gov
> <mailto:nek5000-users at lists.mcs.anl.gov>> wrote:
>> Hi Neks,
>>  I am facing a compilation problem on Blue Gene machine.
>> I get the following message towards the end:
>> I am attaching  the makenek file that I am using for compilation.
>> ld: skipping incompatible $HOME/NEK_2017/3rd_party/gslib/src/libgs.a
>> when searching for -lgs
>> ld: cannot find -lgs
>> Thanks,
>> NN.
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov <mailto:Nek5000-users at lists.mcs.anl.gov>
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>> <makenek>
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20170522/87b9ab99/attachment-0001.html>
mpixlf77_r -qsuppress=cmpmsg -c  -O2 -qrealsize=8 -qdpc=e -qsuffix=cpp=f -WF,-DMPIIO -WF,-DMPI -WF,-DTIMER -I/linkhome/rech/ymm/rymm003/TEST_NEK2017 -I/linkhome/rech/ymm/rymm003/NEK_2017/core -I./ /linkhome/rech/ymm/rymm003/NEK_2017/core/drive.f -o obj/drive.o
mpixlf77_r -qsuppress=cmpmsg -c  -O2 -qrealsize=8 -qdpc=e -qsuffix=cpp=f -WF,-DMPIIO -WF,-DMPI -WF,-DTIMER -I/linkhome/rech/ymm/rymm003/TEST_NEK2017 -I/linkhome/rech/ymm/rymm003/NEK_2017/core -I./ /linkhome/rech/ymm/rymm003/NEK_2017/core/drive1.f -o obj/drive1.o
mpixlf77_r -qsuppress=cmpmsg -c  -O2 -qrealsize=8 -qdpc=e -qsuffix=cpp=f -WF,-DMPIIO -WF,-DMPI -WF,-DTIMER -I/linkhome/rech/ymm/rymm003/TEST_NEK2017 -I/linkhome/rech/ymm/rymm003/NEK_2017/core -I./ /linkhome/rech/ymm/rymm003/NEK_2017/core/drive2.f -o obj/drive2.o
mpixlf77_r -qsuppress=cmpmsg -c  -O2 -qrealsize=8 -qdpc=e -qsuffix=cpp=f -WF,-DMPIIO -WF,-DMPI -WF,-DTIMER -I/linkhome/rech/ymm/rymm003/TEST_NEK2017 -I/linkhome/rech/ymm/rymm003/NEK_2017/core -I./ /linkhome/rech/ymm/rymm003/NEK_2017/core/plan4.f -o obj/plan4.o
mpixlf77_r -qsuppress=cmpmsg -c  -O2 -qrealsize=8 -qdpc=e -qsuffix=cpp=f -WF,-DMPIIO -WF,-DMPI -WF,-DTIMER -I/linkhome/rech/ymm/rymm003/TEST_NEK2017 -I/linkhome/rech/ymm/rymm003/NEK_2017/core -I./ /linkhome/rech/ymm/rymm003/NEK_2017/core/bdry.f -o obj/bdry.o
mpixlf77_r -qsuppress=cmpmsg -c  -O2 -qrealsize=8 -qdpc=e -qsuffix=cpp=f -WF,-DMPIIO -WF,-DMPI -WF,-DTIMER -I/linkhome/rech/ymm/rymm003/TEST_NEK2017 -I/linkhome/rech/ymm/rymm003/NEK_2017/core -I./ /linkhome/rech/ymm/rymm003/NEK_2017/core/coef.f -o obj/coef.o
mpixlf77_r -qsuppress=cmpmsg -c  -O2 -qrealsize=8 -qdpc=e -qsuffix=cpp=f -WF,-DMPIIO -WF,-DMPI -WF,-DTIMER -I/linkhome/rech/ymm/rymm003/TEST_NEK2017 -I/linkhome/rech/ymm/rymm003/NEK_2017/core -I./ /linkhome/rech/ymm/rymm003/NEK_2017/core/conduct.f -o obj/conduct.o
mpixlf77_r -qsuppress=cmpmsg -c  -O2 -qrealsize=8 -qdpc=e -qsuffix=cpp=f -WF,-DMPIIO -WF,-DMPI -WF,-DTIMER -I/linkhome/rech/ymm/rymm003/TEST_NEK2017 -I/linkhome/rech/ymm/rymm003/NEK_2017/core -I./ /linkhome/rech/ymm/rymm003/NEK_2017/core/connect1.f -o obj/connect1.o
mpixlf77_r -qsuppress=cmpmsg -c  -O2 -qrealsize=8 -qdpc=e -qsuffix=cpp=f -WF,-DMPIIO -WF,-DMPI -WF,-DTIMER -I/linkhome/rech/ymm/rymm003/TEST_NEK2017 -I/linkhome/rech/ymm/rymm003/NEK_2017/core -I./ /linkhome/rech/ymm/rymm003/NEK_2017/core/connect2.f -o obj/connect2.o
mpixlf77_r -qsuppress=cmpmsg -c  -O2 -qrealsize=8 -qdpc=e -qsuffix=cpp=f -WF,-DMPIIO -WF,-DMPI -WF,-DTIMER -I/linkhome/rech/ymm/rymm003/TEST_NEK2017 -I/linkhome/rech/ymm/rymm003/NEK_2017/core -I./ /linkhome/rech/ymm/rymm003/NEK_2017/core/dssum.f -o obj/dssum.o
mpixlf77_r -qsuppress=cmpmsg -c  -O2 -qrealsize=8 -qdpc=e -qsuffix=cpp=f -WF,-DMPIIO -WF,-DMPI -WF,-DTIMER -I/linkhome/rech/ymm/rymm003/TEST_NEK2017 -I/linkhome/rech/ymm/rymm003/NEK_2017/core -I./ /linkhome/rech/ymm/rymm003/NEK_2017/core/edgec.f -o obj/edgec.o
mpixlf77_r -qsuppress=cmpmsg -c  -O2 -qrealsize=8 -qdpc=e -qsuffix=cpp=f -WF,-DMPIIO -WF,-DMPI -WF,-DTIMER -I/linkhome/rech/ymm/rymm003/TEST_NEK2017 -I/linkhome/rech/ymm/rymm003/NEK_2017/core -I./ /linkhome/rech/ymm/rymm003/NEK_2017/core/eigsolv.f -o obj/eigsolv.o
mpixlf77_r -qsuppress=cmpmsg -c  -O2 -qrealsize=8 -qdpc=e -qsuffix=cpp=f -WF,-DMPIIO -WF,-DMPI -WF,-DTIMER -I/linkhome/rech/ymm/rymm003/TEST_NEK2017 -I/linkhome/rech/ymm/rymm003/NEK_2017/core -I./ /linkhome/rech/ymm/rymm003/NEK_2017/core/gauss.f -o obj/gauss.o
mpixlf77_r -qsuppress=cmpmsg -c  -O2 -qrealsize=8 -qdpc=e -qsuffix=cpp=f -WF,-DMPIIO -WF,-DMPI -WF,-DTIMER -I/linkhome/rech/ymm/rymm003/TEST_NEK2017 -I/linkhome/rech/ymm/rymm003/NEK_2017/core -I./ /linkhome/rech/ymm/rymm003/NEK_2017/core/genxyz.f -o obj/genxyz.o
mpixlf77_r -qsuppress=cmpmsg -c  -O2 -qrealsize=8 -qdpc=e -qsuffix=cpp=f -WF,-DMPIIO -WF,-DMPI -WF,-DTIMER -I/linkhome/rech/ymm/rymm003/TEST_NEK2017 -I/linkhome/rech/ymm/rymm003/NEK_2017/core -I./ /linkhome/rech/ymm/rymm003/NEK_2017/core/navier1.f -o obj/navier1.o
"/linkhome/rech/ymm/rymm003/NEK_2017/core/navier1.f", line 3342.31: 1511-122 (E) Unconditional GO TO statement refers to statement inside a DO-loop, IF block, CASE construct, SELECT TYPE construct, ASSOCIATE construct, WHERE construct or FORALL construct with label 101.  Transfer of control into a DO-loop, IF block, CASE construct, SELECT TYPE construct, ASSOCIATE construct, WHERE construct or FORALL construct is not permitted.
mpixlf77_r -qsuppress=cmpmsg -c  -O2 -qrealsize=8 -qdpc=e -qsuffix=cpp=f -WF,-DMPIIO -WF,-DMPI -WF,-DTIMER -I/linkhome/rech/ymm/rymm003/TEST_NEK2017 -I/linkhome/rech/ymm/rymm003/NEK_2017/core -I./ /linkhome/rech/ymm/rymm003/NEK_2017/core/makeq.f -o obj/makeq.o
mpixlf77_r -qsuppress=cmpmsg -c  -O2 -qrealsize=8 -qdpc=e -qsuffix=cpp=f -WF,-DMPIIO -WF,-DMPI -WF,-DTIMER -I/linkhome/rech/ymm/rymm003/TEST_NEK2017 -I/linkhome/rech/ymm/rymm003/NEK_2017/core -I./ /linkhome/rech/ymm/rymm003/NEK_2017/core/navier0.f -o obj/navier0.o
mpixlf77_r -qsuppress=cmpmsg -c  -O2 -qrealsize=8 -qdpc=e -qsuffix=cpp=f -WF,-DMPIIO -WF,-DMPI -WF,-DTIMER -I/linkhome/rech/ymm/rymm003/TEST_NEK2017 -I/linkhome/rech/ymm/rymm003/NEK_2017/core -I./ /linkhome/rech/ymm/rymm003/NEK_2017/core/navier2.f -o obj/navier2.o
mpixlf77_r -qsuppress=cmpmsg -c  -O2 -qrealsize=8 -qdpc=e -qsuffix=cpp=f -WF,-DMPIIO -WF,-DMPI -WF,-DTIMER -I/linkhome/rech/ymm/rymm003/TEST_NEK2017 -I/linkhome/rech/ymm/rymm003/NEK_2017/core -I./ /linkhome/rech/ymm/rymm003/NEK_2017/core/navier3.f -o obj/navier3.o
mpixlf77_r -qsuppress=cmpmsg -c  -O2 -qrealsize=8 -qdpc=e -qsuffix=cpp=f -WF,-DMPIIO -WF,-DMPI -WF,-DTIMER -I/linkhome/rech/ymm/rymm003/TEST_NEK2017 -I/linkhome/rech/ymm/rymm003/NEK_2017/core -I./ /linkhome/rech/ymm/rymm003/NEK_2017/core/navier4.f -o obj/navier4.o
mpixlf77_r -qsuppress=cmpmsg -c  -O2 -qrealsize=8 -qdpc=e -qsuffix=cpp=f -WF,-DMPIIO -WF,-DMPI -WF,-DTIMER -I/linkhome/rech/ymm/rymm003/TEST_NEK2017 -I/linkhome/rech/ymm/rymm003/NEK_2017/core -I./ /linkhome/rech/ymm/rymm003/NEK_2017/core/prepost.f -o obj/prepost.o
mpixlf77_r -qsuppress=cmpmsg -c  -O2 -qrealsize=8 -qdpc=e -qsuffix=cpp=f -WF,-DMPIIO -WF,-DMPI -WF,-DTIMER -I/linkhome/rech/ymm/rymm003/TEST_NEK2017 -I/linkhome/rech/ymm/rymm003/NEK_2017/core -I./ /linkhome/rech/ymm/rymm003/NEK_2017/core/speclib.f -o obj/speclib.o
"/linkhome/rech/ymm/rymm003/NEK_2017/core/navier4.f", line 1157.7: 1516-023 (E) Subscript is out of bounds.
mpixlf77_r -qsuppress=cmpmsg -c  -O2 -qrealsize=8 -qdpc=e -qsuffix=cpp=f -WF,-DMPIIO -WF,-DMPI -WF,-DTIMER -I/linkhome/rech/ymm/rymm003/TEST_NEK2017 -I/linkhome/rech/ymm/rymm003/NEK_2017/core -I./ /linkhome/rech/ymm/rymm003/NEK_2017/core/map2.f -o obj/map2.o
mpixlf77_r -qsuppress=cmpmsg -c  -O2 -qrealsize=8 -qdpc=e -qsuffix=cpp=f -WF,-DMPIIO -WF,-DMPI -WF,-DTIMER -I/linkhome/rech/ymm/rymm003/TEST_NEK2017 -I/linkhome/rech/ymm/rymm003/NEK_2017/core -I./ /linkhome/rech/ymm/rymm003/NEK_2017/core/turb.f -o obj/turb.o
mpixlf77_r -qsuppress=cmpmsg -c  -O2 -qrealsize=8 -qdpc=e -qsuffix=cpp=f -WF,-DMPIIO -WF,-DMPI -WF,-DTIMER -I/linkhome/rech/ymm/rymm003/TEST_NEK2017 -I/linkhome/rech/ymm/rymm003/NEK_2017/core -I./ /linkhome/rech/ymm/rymm003/NEK_2017/core/mvmesh.f -o obj/mvmesh.o
mpixlf77_r -qsuppress=cmpmsg -c  -O2 -qrealsize=8 -qdpc=e -qsuffix=cpp=f -WF,-DMPIIO -WF,-DMPI -WF,-DTIMER -I/linkhome/rech/ymm/rymm003/TEST_NEK2017 -I/linkhome/rech/ymm/rymm003/NEK_2017/core -I./ /linkhome/rech/ymm/rymm003/NEK_2017/core/ic.f -o obj/ic.o
mpixlf77_r -qsuppress=cmpmsg -c  -O2 -qrealsize=8 -qdpc=e -qsuffix=cpp=f -WF,-DMPIIO -WF,-DMPI -WF,-DTIMER -I/linkhome/rech/ymm/rymm003/TEST_NEK2017 -I/linkhome/rech/ymm/rymm003/NEK_2017/core -I./ /linkhome/rech/ymm/rymm003/NEK_2017/core/gfldr.f -o obj/gfldr.o
mpixlf77_r -qsuppress=cmpmsg -c  -O2 -qrealsize=8 -qdpc=e -qsuffix=cpp=f -WF,-DMPIIO -WF,-DMPI -WF,-DTIMER -I/linkhome/rech/ymm/rymm003/TEST_NEK2017 -I/linkhome/rech/ymm/rymm003/NEK_2017/core -I./ /linkhome/rech/ymm/rymm003/NEK_2017/core/ssolv.f -o obj/ssolv.o
mpixlf77_r -qsuppress=cmpmsg -c  -O2 -qrealsize=8 -qdpc=e -qsuffix=cpp=f -WF,-DMPIIO -WF,-DMPI -WF,-DTIMER -I/linkhome/rech/ymm/rymm003/TEST_NEK2017 -I/linkhome/rech/ymm/rymm003/NEK_2017/core -I./ /linkhome/rech/ymm/rymm003/NEK_2017/core/planx.f -o obj/planx.o
mpixlf77_r -qsuppress=cmpmsg -c  -O3 -qrealsize=8 -qdpc=e -qsuffix=cpp=f -WF,-DMPIIO -WF,-DMPI -WF,-DTIMER -I/linkhome/rech/ymm/rymm003/TEST_NEK2017 -I/linkhome/rech/ymm/rymm003/NEK_2017/core -I./ /linkhome/rech/ymm/rymm003/NEK_2017/core/math.f -o obj/math.o
mpixlf77_r -qsuppress=cmpmsg -c  -O2 -qrealsize=8 -qdpc=e -qsuffix=cpp=f -WF,-DMPIIO -WF,-DMPI -WF,-DTIMER -I/linkhome/rech/ymm/rymm003/TEST_NEK2017 -I/linkhome/rech/ymm/rymm003/NEK_2017/core -I./ /linkhome/rech/ymm/rymm003/NEK_2017/core/mxm_wrapper.f -o obj/mxm_wrapper.o
mpixlf77_r -qsuppress=cmpmsg -c  -O2 -qrealsize=8 -qdpc=e -qsuffix=cpp=f -WF,-DMPIIO -WF,-DMPI -WF,-DTIMER -I/linkhome/rech/ymm/rymm003/TEST_NEK2017 -I/linkhome/rech/ymm/rymm003/NEK_2017/core -I./ /linkhome/rech/ymm/rymm003/NEK_2017/core/hmholtz.f -o obj/hmholtz.o
mpixlf77_r -qsuppress=cmpmsg -c  -O2 -qrealsize=8 -qdpc=e -qsuffix=cpp=f -WF,-DMPIIO -WF,-DMPI -WF,-DTIMER -I/linkhome/rech/ymm/rymm003/TEST_NEK2017 -I/linkhome/rech/ymm/rymm003/NEK_2017/core -I./ /linkhome/rech/ymm/rymm003/NEK_2017/core/gfdm_par.f -o obj/gfdm_par.o
mpixlf77_r -qsuppress=cmpmsg -c  -O2 -qrealsize=8 -qdpc=e -qsuffix=cpp=f -WF,-DMPIIO -WF,-DMPI -WF,-DTIMER -I/linkhome/rech/ymm/rymm003/TEST_NEK2017 -I/linkhome/rech/ymm/rymm003/NEK_2017/core -I./ /linkhome/rech/ymm/rymm003/NEK_2017/core/gfdm_op.f -o obj/gfdm_op.o
mpixlf77_r -qsuppress=cmpmsg -c  -O2 -qrealsize=8 -qdpc=e -qsuffix=cpp=f -WF,-DMPIIO -WF,-DMPI -WF,-DTIMER -I/linkhome/rech/ymm/rymm003/TEST_NEK2017 -I/linkhome/rech/ymm/rymm003/NEK_2017/core -I./ /linkhome/rech/ymm/rymm003/NEK_2017/core/gfdm_solve.f -o obj/gfdm_solve.o
mpixlf77_r -qsuppress=cmpmsg -c  -O2 -qrealsize=8 -qdpc=e -qsuffix=cpp=f -WF,-DMPIIO -WF,-DMPI -WF,-DTIMER -I/linkhome/rech/ymm/rymm003/TEST_NEK2017 -I/linkhome/rech/ymm/rymm003/NEK_2017/core -I./ /linkhome/rech/ymm/rymm003/NEK_2017/core/subs1.f -o obj/subs1.o
mpixlf77_r -qsuppress=cmpmsg -c  -O2 -qrealsize=8 -qdpc=e -qsuffix=cpp=f -WF,-DMPIIO -WF,-DMPI -WF,-DTIMER -I/linkhome/rech/ymm/rymm003/TEST_NEK2017 -I/linkhome/rech/ymm/rymm003/NEK_2017/core -I./ /linkhome/rech/ymm/rymm003/NEK_2017/core/subs2.f -o obj/subs2.o
mpixlf77_r -qsuppress=cmpmsg -c  -O2 -qrealsize=8 -qdpc=e -qsuffix=cpp=f -WF,-DMPIIO -WF,-DMPI -WF,-DTIMER -I/linkhome/rech/ymm/rymm003/TEST_NEK2017 -I/linkhome/rech/ymm/rymm003/NEK_2017/core -I./ /linkhome/rech/ymm/rymm003/NEK_2017/core/genbox.f -o obj/genbox.o
"/linkhome/rech/ymm/rymm003/NEK_2017/core/math.f", 1500-036 (I) The NOSTRICT option (default at OPT(3)) has the potential to alter the semantics of a program.  Please refer to documentation on the STRICT/NOSTRICT option for more information.
mpixlf77_r -qsuppress=cmpmsg -c  -O2 -qrealsize=8 -qdpc=e -qsuffix=cpp=f -WF,-DMPIIO -WF,-DMPI -WF,-DTIMER -I/linkhome/rech/ymm/rymm003/TEST_NEK2017 -I/linkhome/rech/ymm/rymm003/NEK_2017/core -I./ /linkhome/rech/ymm/rymm003/NEK_2017/core/gmres.f -o obj/gmres.o
mpixlf77_r -qsuppress=cmpmsg -c  -O2 -qrealsize=8 -qdpc=e -qsuffix=cpp=f -WF,-DMPIIO -WF,-DMPI -WF,-DTIMER -I/linkhome/rech/ymm/rymm003/TEST_NEK2017 -I/linkhome/rech/ymm/rymm003/NEK_2017/core -I./ /linkhome/rech/ymm/rymm003/NEK_2017/core/hsmg.f -o obj/hsmg.o
mpixlf77_r -qsuppress=cmpmsg -c  -O2 -qrealsize=8 -qdpc=e -qsuffix=cpp=f -WF,-DMPIIO -WF,-DMPI -WF,-DTIMER -I/linkhome/rech/ymm/rymm003/TEST_NEK2017 -I/linkhome/rech/ymm/rymm003/NEK_2017/core -I./ /linkhome/rech/ymm/rymm003/NEK_2017/core/convect.f -o obj/convect.o
mpixlf77_r -qsuppress=cmpmsg -c  -O2 -qrealsize=8 -qdpc=e -qsuffix=cpp=f -WF,-DMPIIO -WF,-DMPI -WF,-DTIMER -I/linkhome/rech/ymm/rymm003/TEST_NEK2017 -I/linkhome/rech/ymm/rymm003/NEK_2017/core -I./ /linkhome/rech/ymm/rymm003/NEK_2017/core/induct.f -o obj/induct.o
mpixlf77_r -qsuppress=cmpmsg -c  -O2 -qrealsize=8 -qdpc=e -qsuffix=cpp=f -WF,-DMPIIO -WF,-DMPI -WF,-DTIMER -I/linkhome/rech/ymm/rymm003/TEST_NEK2017 -I/linkhome/rech/ymm/rymm003/NEK_2017/core -I./ /linkhome/rech/ymm/rymm003/NEK_2017/core/perturb.f -o obj/perturb.o
mpixlf77_r -qsuppress=cmpmsg -c  -O2 -qrealsize=8 -qdpc=e -qsuffix=cpp=f -WF,-DMPIIO -WF,-DMPI -WF,-DTIMER -I/linkhome/rech/ymm/rymm003/TEST_NEK2017 -I/linkhome/rech/ymm/rymm003/NEK_2017/core -I./ /linkhome/rech/ymm/rymm003/NEK_2017/core/navier5.f -o obj/navier5.o
mpixlf77_r -qsuppress=cmpmsg -c  -O2 -qrealsize=8 -qdpc=e -qsuffix=cpp=f -WF,-DMPIIO -WF,-DMPI -WF,-DTIMER -I/linkhome/rech/ymm/rymm003/TEST_NEK2017 -I/linkhome/rech/ymm/rymm003/NEK_2017/core -I./ /linkhome/rech/ymm/rymm003/NEK_2017/core/navier6.f -o obj/navier6.o
mpixlf77_r -qsuppress=cmpmsg -c  -O2 -qrealsize=8 -qdpc=e -qsuffix=cpp=f -WF,-DMPIIO -WF,-DMPI -WF,-DTIMER -I/linkhome/rech/ymm/rymm003/TEST_NEK2017 -I/linkhome/rech/ymm/rymm003/NEK_2017/core -I./ /linkhome/rech/ymm/rymm003/NEK_2017/core/navier7.f -o obj/navier7.o
mpixlf77_r -qsuppress=cmpmsg -c  -O2 -qrealsize=8 -qdpc=e -qsuffix=cpp=f -WF,-DMPIIO -WF,-DMPI -WF,-DTIMER -I/linkhome/rech/ymm/rymm003/TEST_NEK2017 -I/linkhome/rech/ymm/rymm003/NEK_2017/core -I./ /linkhome/rech/ymm/rymm003/NEK_2017/core/navier8.f -o obj/navier8.o
mpixlf77_r -qsuppress=cmpmsg -c  -O2 -qrealsize=8 -qdpc=e -qsuffix=cpp=f -WF,-DMPIIO -WF,-DMPI -WF,-DTIMER -I/linkhome/rech/ymm/rymm003/TEST_NEK2017 -I/linkhome/rech/ymm/rymm003/NEK_2017/core -I./ /linkhome/rech/ymm/rymm003/NEK_2017/core/fast3d.f -o obj/fast3d.o
mpixlf77_r -qsuppress=cmpmsg -c  -O2 -qrealsize=8 -qdpc=e -qsuffix=cpp=f -WF,-DMPIIO -WF,-DMPI -WF,-DTIMER -I/linkhome/rech/ymm/rymm003/TEST_NEK2017 -I/linkhome/rech/ymm/rymm003/NEK_2017/core -I./ /linkhome/rech/ymm/rymm003/NEK_2017/core/fasts.f -o obj/fasts.o
mpixlf77_r -qsuppress=cmpmsg -c  -O2 -qrealsize=8 -qdpc=e -qsuffix=cpp=f -WF,-DMPIIO -WF,-DMPI -WF,-DTIMER -I/linkhome/rech/ymm/rymm003/TEST_NEK2017 -I/linkhome/rech/ymm/rymm003/NEK_2017/core -I./ /linkhome/rech/ymm/rymm003/NEK_2017/core/calcz.f -o obj/calcz.o
mpixlc_r -c  -O2  -DMPIIO -DMPI -DTIMER /linkhome/rech/ymm/rymm003/NEK_2017/core/byte.c -o obj/byte.o
mpixlc_r -c  -O2  -DMPIIO -DMPI -DTIMER /linkhome/rech/ymm/rymm003/NEK_2017/core/chelpers.c -o obj/chelpers.o
mpixlf77_r -qsuppress=cmpmsg -c  -O2 -qrealsize=8 -qdpc=e -qsuffix=cpp=f -WF,-DMPIIO -WF,-DMPI -WF,-DTIMER -I/linkhome/rech/ymm/rymm003/TEST_NEK2017 -I/linkhome/rech/ymm/rymm003/NEK_2017/core -I./ /linkhome/rech/ymm/rymm003/NEK_2017/core/byte_mpi.f -o obj/byte_mpi.o
mpixlf77_r -qsuppress=cmpmsg -c  -O2 -qrealsize=8 -qdpc=e -qsuffix=cpp=f -WF,-DMPIIO -WF,-DMPI -WF,-DTIMER -I/linkhome/rech/ymm/rymm003/TEST_NEK2017 -I/linkhome/rech/ymm/rymm003/NEK_2017/core -I./ /linkhome/rech/ymm/rymm003/NEK_2017/core/postpro.f -o obj/postpro.o
mpixlf77_r -qsuppress=cmpmsg -c  -O2 -qrealsize=8 -qdpc=e -qsuffix=cpp=f -WF,-DMPIIO -WF,-DMPI -WF,-DTIMER -I/linkhome/rech/ymm/rymm003/TEST_NEK2017 -I/linkhome/rech/ymm/rymm003/NEK_2017/core -I./ /linkhome/rech/ymm/rymm003/NEK_2017/core/intp_usr.f -o obj/intp_usr.o
mpixlf77_r -qsuppress=cmpmsg -c  -O2 -qrealsize=8 -qdpc=e -qsuffix=cpp=f -WF,-DMPIIO -WF,-DMPI -WF,-DTIMER -I/linkhome/rech/ymm/rymm003/TEST_NEK2017 -I/linkhome/rech/ymm/rymm003/NEK_2017/core -I./ /linkhome/rech/ymm/rymm003/NEK_2017/core/cvode_driver.f -o obj/cvode_driver.o
mpixlc_r -c  -O2  -DMPIIO -DMPI -DTIMER /linkhome/rech/ymm/rymm003/NEK_2017/core/nek_comm.c -o obj/nek_comm.o
mpixlf77_r -qsuppress=cmpmsg -c  -O2 -qrealsize=8 -qdpc=e -qsuffix=cpp=f -WF,-DMPIIO -WF,-DMPI -WF,-DTIMER -I/linkhome/rech/ymm/rymm003/TEST_NEK2017 -I/linkhome/rech/ymm/rymm003/NEK_2017/core -I./ /linkhome/rech/ymm/rymm003/NEK_2017/core/vprops.f -o obj/vprops.o
mpixlf77_r -qsuppress=cmpmsg -c  -O2 -qrealsize=8 -qdpc=e -qsuffix=cpp=f -WF,-DMPIIO -WF,-DMPI -WF,-DTIMER -I/linkhome/rech/ymm/rymm003/TEST_NEK2017 -I/linkhome/rech/ymm/rymm003/NEK_2017/core -I./ /linkhome/rech/ymm/rymm003/NEK_2017/core/makeq_aux.f -o obj/makeq_aux.o
mpixlf77_r -qsuppress=cmpmsg -c  -O2 -qrealsize=8 -qdpc=e -qsuffix=cpp=f -WF,-DMPIIO -WF,-DMPI -WF,-DTIMER -I/linkhome/rech/ymm/rymm003/TEST_NEK2017 -I/linkhome/rech/ymm/rymm003/NEK_2017/core -I./ /linkhome/rech/ymm/rymm003/NEK_2017/core/papi.f -o obj/papi.o
mpixlf77_r -qsuppress=cmpmsg -c   -O2 -qrealsize=8 -qdpc=e -qsuffix=cpp=f -WF,-DMPIIO -WF,-DMPI -WF,-DTIMER -I/linkhome/rech/ymm/rymm003/TEST_NEK2017 -I/linkhome/rech/ymm/rymm003/NEK_2017/core -I./ /linkhome/rech/ymm/rymm003/NEK_2017/core/3rd_party/nek_in_situ.f -o obj/nek_in_situ.o
mpixlf77_r -qsuppress=cmpmsg -c  -O2 -qrealsize=8 -qdpc=e -qsuffix=cpp=f -WF,-DMPIIO -WF,-DMPI -WF,-DTIMER -I/linkhome/rech/ymm/rymm003/TEST_NEK2017 -I/linkhome/rech/ymm/rymm003/NEK_2017/core -I./ /linkhome/rech/ymm/rymm003/NEK_2017/core/readat_new.f -o obj/readat_new.o
mpixlf77_r -qsuppress=cmpmsg -c  -O2 -qrealsize=8 -qdpc=e -qsuffix=cpp=f -WF,-DMPIIO -WF,-DMPI -WF,-DTIMER -I/linkhome/rech/ymm/rymm003/TEST_NEK2017 -I/linkhome/rech/ymm/rymm003/NEK_2017/core -I./ /linkhome/rech/ymm/rymm003/NEK_2017/core/reader_re2.f -o obj/reader_re2.o
"/linkhome/rech/ymm/rymm003/NEK_2017/core/reader_re2.f", line 176.24: 1513-041 (W) Arguments of the wrong type were specified for the INTRINSIC procedure "mod".
"/linkhome/rech/ymm/rymm003/NEK_2017/core/reader_re2.f", line 282.24: 1513-041 (W) Arguments of the wrong type were specified for the INTRINSIC procedure "mod".
mpixlc_r  -c  -O2  -DMPIIO -DMPI -DTIMER  /linkhome/rech/ymm/rymm003/NEK_2017/core/3rd_party/finiparser.c -o obj/finiparser.o
mpixlc_r  -c  -O2  -DMPIIO -DMPI -DTIMER  /linkhome/rech/ymm/rymm003/NEK_2017/core/3rd_party/iniparser.c -o obj/iniparser.o
mpixlc_r  -c  -O2  -DMPIIO -DMPI -DTIMER  /linkhome/rech/ymm/rymm003/NEK_2017/core/3rd_party/dictionary.c -o obj/dictionary.o
mpixlf77_r -qsuppress=cmpmsg -c  -O3 -qrealsize=8 -qdpc=e -qsuffix=cpp=f -WF,-DMPIIO -WF,-DMPI -WF,-DTIMER -I/linkhome/rech/ymm/rymm003/TEST_NEK2017 -I/linkhome/rech/ymm/rymm003/NEK_2017/core -I./ /linkhome/rech/ymm/rymm003/NEK_2017/core/mxm_std.f -o obj/mxm_std.o
mpixlf77_r -qsuppress=cmpmsg -c  -O2 -qrealsize=8 -qdpc=e -qsuffix=cpp=f -WF,-DMPIIO -WF,-DMPI -WF,-DTIMER -I/linkhome/rech/ymm/rymm003/TEST_NEK2017 -I/linkhome/rech/ymm/rymm003/NEK_2017/core -I./ /linkhome/rech/ymm/rymm003/NEK_2017/core/comm_mpi.f -o obj/comm_mpi.o
mpixlf77_r -qsuppress=cmpmsg -c  -O2 -qrealsize=8 -qdpc=e -qsuffix=cpp=f -WF,-DMPIIO -WF,-DMPI -WF,-DTIMER -I/linkhome/rech/ymm/rymm003/TEST_NEK2017 -I/linkhome/rech/ymm/rymm003/NEK_2017/core -I./ /linkhome/rech/ymm/rymm003/NEK_2017/core/singlmesh.f -o obj/singlmesh.o
mpixlf77_r -qsuppress=cmpmsg -c  -O0 -WF,-DMPIIO -WF,-DMPI -WF,-DTIMER /linkhome/rech/ymm/rymm003/NEK_2017/core/3rd_party/blas.f -o obj/blas.o
mpixlf77_r -qsuppress=cmpmsg -c  -O0 -WF,-DMPIIO -WF,-DMPI -WF,-DTIMER /linkhome/rech/ymm/rymm003/NEK_2017/core/3rd_party/dsygv.f -o obj/dsygv.o
"/linkhome/rech/ymm/rymm003/NEK_2017/core/mxm_std.f", 1500-036 (I) The NOSTRICT option (default at OPT(3)) has the potential to alter the semantics of a program.  Please refer to documentation on the STRICT/NOSTRICT option for more information.
mpixlf77_r -qsuppress=cmpmsg -c  -O2 -qrealsize=8 -qdpc=e -qsuffix=cpp=f -WF,-DMPIIO -WF,-DMPI -WF,-DTIMER -I/linkhome/rech/ymm/rymm003/TEST_NEK2017 -I/linkhome/rech/ymm/rymm003/NEK_2017/core -I./ /linkhome/rech/ymm/rymm003/TEST_NEK2017/WING.f  -o obj/WING.o
mpixlf77_r -qsuppress=cmpmsg -o nek5000 obj/WING.o obj/drive.o obj/drive1.o obj/drive2.o obj/plan4.o obj/bdry.o obj/coef.o obj/conduct.o obj/connect1.o obj/connect2.o obj/dssum.o obj/edgec.o obj/eigsolv.o obj/gauss.o obj/genxyz.o obj/navier1.o obj/makeq.o obj/navier0.o obj/navier2.o obj/navier3.o obj/navier4.o obj/prepost.o obj/speclib.o obj/map2.o obj/turb.o obj/mvmesh.o obj/ic.o obj/gfldr.o obj/ssolv.o obj/planx.o obj/math.o obj/mxm_wrapper.o obj/hmholtz.o obj/gfdm_par.o obj/gfdm_op.o obj/gfdm_solve.o obj/subs1.o obj/subs2.o obj/genbox.o obj/gmres.o obj/hsmg.o obj/convect.o obj/induct.o obj/perturb.o obj/navier5.o obj/navier6.o obj/navier7.o obj/navier8.o obj/fast3d.o obj/fasts.o obj/calcz.o obj/byte.o obj/chelpers.o obj/byte_mpi.o obj/postpro.o obj/intp_usr.o obj/cvode_driver.o obj/nek_comm.o obj/vprops.o obj/makeq_aux.o obj/papi.o obj/nek_in_situ.o obj/readat_new.o obj/reader_re2.o obj/finiparser.o obj/iniparser.o obj/dictionary.o obj/mxm_std.o obj/comm_mpi.o obj/singlmesh.o obj/blas.o obj/dsygv.o -L/linkhome/rech/ymm/rymm003/NEK_2017/3rd_party/gslib/src -lgs
ld: skipping incompatible /linkhome/rech/ymm/rymm003/NEK_2017/3rd_party/gslib/src/libgs.a when searching for -lgs
make: *** [nek5000] Error 1
