[Nek5000-users] Crash when implementing additional scalars
Mon May 15 02:40:25 CDT 2017
Thank you, this solved the problem!
Now all scalars behave identically as they should and no crash.
How should I understand the reason for the previous crash?
From: nek5000-users-bounces at lists.mcs.anl.gov <nek5000-users-bounces at lists.mcs.anl.gov> on behalf of nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
Sent: Sunday, May 14, 2017 7:30 PM
To: nek5000-users at lists.mcs.anl.gov
Subject: Re: [Nek5000-users] Crash when implementing additional scalars
Dear Johan,
Try setting param 94=0 in your .rea file.
Best,
Paul
From: nek5000-users-bounces at lists.mcs.anl.gov [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
Sent: Sunday, May 14, 2017 12:26 PM
Subject: [Nek5000-users] Crash when implementing additional scalars
Dear Neks,
I get the following crash when implementing 3 scalar fields (temperature + 2 additional scalar fields):
Step      4, t= 4.0000000E-03, DT= 1.0000000E-03, C=  0.331 7.1728E+01 2.2114E+01
             Solving for heat
 Solving for fluid F T T
       4   2.51148E-02   6.07580E-04   4.13357E+01   1 TEMP   PROJECT
          4    Hmholtz TEMP:      4   3.0551E-08   8.0302E-04   1.0000E-07
       4   2.51148E-02   1.60663E-08   1.56319E+06   2 PS 1   PROJECT
          4    Hmholtz PS 1:      0   3.0509E-08   3.0509E-08   1.0000E-07
       4   2.51148E-02   3.38605E-02   7.41712E-01   3 PS 2   PROJECT
     4   100 **ERROR**: Failed in HMHOLTZ: PS 2   1.6090E+10   5.4264E-02   1.0000E-07
        4proj_ortho:    3   4 PS 2   Detect rank deficiency:         NaN  1.0000E+00
        4proj_ortho:    2   4 PS 2   Detect rank deficiency:         NaN  1.0000E+00
        4proj_ortho:    1   4 PS 2   Detect rank deficiency:         NaN  1.0000E+00
          4   4.0000E-03  1.2605E+01 Heat done
 Reorthogonalize Basis:
       4   2.21548E-02   2.27058E-02   9.75731E-01   1 velx   PROJECT
          4    Hmholtz velx:      5   7.8903E-08   4.8255E-02   1.0000E-07
       4   2.21455E-02   2.26942E-02   9.75823E-01   1 vely   PROJECT
          4    Hmholtz vely:      5   7.8987E-08   4.8248E-02   1.0000E-07
       4   2.54684E-01   2.57237E-01   9.90076E-01   1 velz   PROJECT
          4    Hmholtz velz:      6   1.7695E-08   5.4216E-01   1.0000E-07
         4 U-PRES gmres:     13  9.8513E-07  1.0000E-06  3.0328E-03  1.1984E+00  4.7670E+00
          4   4.0000E-03  8.4136E+00 Fluid done
          4  4 qfilt:  6.2753E-08  1.4966E-07  4.9326E-10
  5.7232E-14  5.7288E-14  2.1974E+09
The strange thing is that this does not happen when I run with only temperature.
I develop my simulation in small steps, but at the step when I also simulate the scalars (that are treated identically as the temperature), I get this crash.
I wonder if there is somthing that I missed when increasing the number of scalars?
Below I describe how I set up the simulation.
Best,
Johan
*** Only temperature case ***
I generate a mesh from six .box files using genbox. The corresponding .rea files were modified slightly, merged and extended to 3D using n2to3.
The 3D .rea files were merged using nekmerge2.
If I start from .box files with only temperature I get a .rea file with p023 = 0 (NPSCAL).
I set the Peclet number to -233, and the field settings to
 T T F F F F F F F F F  IFNAV & IFADVC (convection in P.S. fields)
 F F T T T T T T T T T T  IFTMSH (IF mesh for this field is T mesh)
end everything works excellently.
*** 3 scalar case ***
If modify the previously mentioned .box files by adding 2 to the number of fields, and adding the same BC:s to them.
I get a .rea file with p023 = 2 (NPSCAL).
I set the Peclet number for the new scalars to -233, so that they are the same as for the temperature.
I change the field settings to:
 T T T T F F F F F F F  IFNAV & IFADVC (convection in P.S. fields)
 F F F F T T T T T T T T  IFTMSH (IF mesh for this field is T mesh)
Now I get the crash described above.
*** The .usr file***
The temperature is read out in userf as:
      ffz = -t(ix,iy,iz,e,1)/1.32
All the scalars have the same boundary and initial conditions (they enter useric and userf only as "temp").
*** The SIZE file ***
I use the maximum number of passive scalars (ldimt) = 4 for both cases.
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20170515/c03e3dd3/attachment.html>
