[Nek5000-users] Copy velocity slice from one boundary to another
Fri Mar 24 12:52:28 CDT 2017
Vatslav,
you will have to use the neknek script that allows you to exchange data between two Nek5000 sessions that are run simultaneously. You should have a look at the neknek examples to understand how to set up your usr file.
Some of the subroutines that will be useful to you are located in the following link: http://www.mcs.anl.gov/research/projects/nek5/docs/html/multimesh_8f_source.html
You will have to modify some of them to fit your needs since for example the subroutine ‘set_inflag’ is written to look for ‘in’ boundary conditions and replace them with ‘v  ’. You will need a subroutine that looks for ‘in’ and substitute it with either ‘v  ‘ or ‘P  ‘ depending on the which pipe you are at.
Marco
On Mar 24, 2017, at 4:16 AM, nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov> wrote:
Hi, Neks!
I have two pipes in my simulation. They are placed near each other on one axis with empty space between.
One of them with periodic boundary conditions on z direction, another one - inflow -> outflow.
How can I copy velocity slice from one of boundary on first pipe with periodic bc to the inflow boundary on second pipe?
Regards, Vatslav.
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl.gov<mailto:Nek5000-users at lists.mcs.anl.gov>
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20170324/1b3de957/attachment.html>
