[Nek5000-users] VISIT visnek skip some timesteps
Tue Mar 7 14:09:39 CST 2017
I suspect that you can open only first file you transferred blah0.00001
To open the rest of file in VisIt, I typically create a separate file with sequentially numbered files *01, *02, etc. that point/link to the original transferred non-sequentially-numbered files
Aleks
From: nek5000-users-bounces at lists.mcs.anl.gov [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
Sent: Tuesday, March 07, 2017 2:01 PM
To: nek5000-users at lists.mcs.anl.gov
Subject: Re: [Nek5000-users] VISIT visnek skip some timesteps
you can change the total number of time steps in the blah.nek5000 file. The example from the documentation for this case is:
NEK5000
version: 1.0
filetemplate:  example%02d.f%04d
firsttimestep: 1
numtimesteps: 1
Am 07.03.2017 um 20:55 schrieb nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov>:
Dear Neks,
I generate blah0.00001, blah0.00002, .....blah0.f00101 on a remote computer. But, I transfer only blah0.f0*1 because of slow transfer speeds. When I run visit, it throw error from the second frame (timestep)
Can someone kindly let me know how should the blah.nek5000 file be modified in order to visualize in VISIT?
When I transfer all the files there is no problem in running VISIT.
Thank you in advance.
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl.gov<mailto:Nek5000-users at lists.mcs.anl.gov>
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20170307/29d611ce/attachment.html>
