[Nek5000-users] Nek: abnormal termination by signal 11
Tue Mar 7 07:17:56 CST 2017
Hi Jan,
I don't know if this helps, but this is the makenek script I use on BGQ.
Paul
From: nek5000-users-bounces at lists.mcs.anl.gov [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
Sent: Tuesday, March 07, 2017 1:31 AM
To: nek5000-users at lists.mcs.anl.gov
Subject: Re: [Nek5000-users] Nek: abnormal termination by signal 11
Hello Paul,
I’m working on the Juqueen IBM BlueGene/Q in Juelich. (http://www.fz-juelich.de/ias/jsc/EN/Expertise/Supercomputers/JUQUEEN/Configuration/Configuration_node.html)
Jan
> Am 07.03.2017 um 04:15 schrieb nek5000-users at lists.mcs.anl.gov:
> Hi Jan,
> Sorry if you've already answered this question Which machine are you running on?
> Paul
> Sent: Monday, March 06, 2017 4:31 AM
> Hello again,
> after some more trying around I got some of my cases to work again by doing a complete reset of the simulations - I was slowly increasing a forcing parameter, and by starting at zero again it seemed to work this time. Other simulations are still failing, even with the new Nek version 17.0. I directly copy the case folders between the clusters and only change the compilers in makenek and number of processors in SIZE, but the cases still work on Intel but fail on IBM.
>> Am 01.03.2017 um 11:18 schrieb nek5000-users at lists.mcs.anl.gov:
>> The stenosis example is working fine with a restart. I found an older case from a few months ago that is still working fine, so I copied its .usr file to one of the new cases and it still failed, so I am suspecting that the error might be related to the grid. The parameters in the rea file are also largely the same.
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
Desc: makenek.bgq
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20170307/7b2991bc/attachment.obj>
