[Nek5000-users] An abrupt error of "unconverged Helmh3 fluid"
Tue Jun 6 08:33:50 CDT 2017
Pend,
can you please give more details on the case you are trying to run with Nek5000? How did you set up your case? Did you start from one of the examples?
Thanks.
> On Jun 6, 2017, at 9:27 AM, nek5000-users at lists.mcs.anl.gov wrote:
> Dear Neks,
> I am using the moving mesh to simulate surface gravity waves with some random heat flux at the surface.
> The codes ran well for a while, but it suddenly pop out an error of unconverged Helmh3 fluid, as shown in the below log file (Step 14650).
> Could anyone give me a hint on this kind of error?
> Thank you,
> Peng
> Step  14647, t= 7.3235000E+01, DT= 5.0000000E-03, C=  0.036 2.8716E+04 1.9695E+00
>             Solving for Hmholtz scalars
>      14647  Hmholtz TEMP       4   6.0654E-16   1.4699E-01   1.0000E-12
>      14647  Scalars done  7.3235E+01  3.9568E-02
>             Solving for fluid
>      14647  Helmh3 fluid       4   1.9934E-13   8.0532E-04   1.0000E-12
>      14647  U-PRES gmres      14   4.5296E-11   2.2779E-03   1.0000E-10   8.2958E-02   2.5954E-01
>      14647  Fluid done  7.3235E+01  3.7241E-01
> Step  14648, t= 7.3240000E+01, DT= 5.0000000E-03, C=  0.035 2.8718E+04 1.9642E+00
>      14648  Hmholtz TEMP       4   6.0987E-16   1.4701E-01   1.0000E-12
>      14648  Scalars done  7.3240E+01  3.9551E-02
>             Solving for fluid
>      14648  Helmh3 fluid       4   1.9904E-13   8.0535E-04   1.0000E-12
>      14648  U-PRES gmres      14   4.5647E-11   2.2779E-03   1.0000E-10   8.3140E-02   2.5985E-01
>      14648  Fluid done  7.3240E+01  3.7297E-01
> Step  14649, t= 7.3245000E+01, DT= 5.0000000E-03, C=  0.034 2.8720E+04 1.9658E+00
>      14649  Hmholtz TEMP       4   6.1309E-16   1.4704E-01   1.0000E-12
>      14649  Scalars done  7.3245E+01  3.9058E-02
>             Solving for fluid
>      14649  Helmh3 fluid       4   1.9875E-13   8.0535E-04   1.0000E-12
>      14649  U-PRES gmres      14   4.5884E-11   2.2778E-03   1.0000E-10   8.3552E-02   2.5956E-01
>      14649  Fluid done  7.3245E+01  3.7226E-01
> Step  14650, t= 7.3250000E+01, DT= 5.0000000E-03, C=  0.033 2.8722E+04 1.9614E+00
>      14650  Hmholtz TEMP       4   6.1615E-16   1.4707E-01   1.0000E-12
>      14650  Scalars done  7.3250E+01  3.9481E-02
>             Solving for fluid
> 14650   201 Unconverged Helmh3 fluid rbnorm =          NaN 0.100000E-11
>      14650  U-PRES gmres     120          NaN          NaN   1.0000E-10   7.0555E-01   2.3985E+00
>      14650  Fluid done  7.3250E+01  5.4078E+00
> Step  14651, t= 7.3255000E+01, DT= 5.0000000E-03, C=    NaN 2.8729E+04 7.0068E+00
>      14651  Error Hmholtz TEMP     200          NaN          NaN   1.0000E-12
>      14651  Scalars done  7.3255E+01  1.0293E+00
>             Solving for fluid
> 14651   201 Unconverged Helmh3 fluid rbnorm =          NaN 0.100000E-11
>      14651  U-PRES gmres     120          NaN          NaN   1.0000E-10   7.0602E-01   2.4098E+00
>      14651  Fluid done  7.3255E+01  5.3955E+00
> Step  14652, t= 7.3260000E+01, DT= 5.0000000E-03, C=    NaN 2.8738E+04 9.1272E+00
>      14652  Error Hmholtz TEMP     200          NaN          NaN   1.0000E-12
>      14652  Scalars done  7.3260E+01  1.0415E+00
>             Solving for fluid
> 14652   201 Unconverged Helmh3 fluid rbnorm =          NaN 0.100000E-11
>      14652  U-PRES gmres     120          NaN          NaN   1.0000E-10   7.0562E-01   2.3933E+00
>      14652  Fluid done  7.3260E+01  5.3900E+00
> Nek5000-users mailing list
