[Nek5000-users] Contents of Nek5000-users digest Corner elements giving large values
Mon Jun 5 12:26:01 CDT 2017
Swarandeep,
Another issue that can arise in RBC simulations is poor numerical
conditioning due to the non-dimensionalization.  The non-dimensional form
of the equations used in the Nek5000 examples is based off the conduction
scales which result in a very small time-step and large velocities at
larger Ra.  I don't think you're case is high enough for it to be a
problem, but you might try using the "freefall" scales if you aren't
already.
I suggest consulting the Scheel, Emran and Schumacher paper for some
details on running an RBC simulation with Nek5000.
Scheel, Janet D., Mohammad S. Emran, and Jörg Schumacher. "Resolving the
fine-scale structure in turbulent Rayleigh–Bénard convection." *New Journal
of Physics* 15.11 (2013): 113063.
Kind Regards,
Phil S.
On Mon, Jun 5, 2017 at 10:00 AM, <nek5000-users-request at lists.mcs.anl.gov>
wrote:
> Send Nek5000-users mailing list submissions to
> To subscribe or unsubscribe via the World Wide Web, visit
>         https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>         nek5000-users-owner at lists.mcs.anl.gov
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of Nek5000-users digest..."
> Today's Topics:
>    1. Re: Corner elements giving large values
>       (nek5000-users at lists.mcs.anl.gov)
>    2. Re: Corner elements giving large values
> Message: 1
> Date: Mon, 5 Jun 2017 01:12:39 +0530
> From: nek5000-users at lists.mcs.anl.gov
> To: nek5000-users at lists.mcs.anl.gov
> Subject: Re: [Nek5000-users] Corner elements giving large values
> Message-ID:
>         <mailman.7988.1496605362.2967.nek5000-users at lists.mcs.anl.gov>
> Content-Type: text/plain; charset="UTF-8"
> Hi Nek Forum, Paul
>      Thanks for the suggestions. I implemented them. Waiting for the
> simulation to be over.
> Another issue I have is that the BC for T at the inner cylinder wall
> does not stay at 0 as I have given in userbc. It becomes 0.2 over some
> time.
> Thank you
> Swarandeep
> On Fri, Jun 2, 2017 at 10:28 PM,  <nek5000-users at lists.mcs.anl.gov> wrote:
> > Hi Swarandeep,
> > Set p26 in the .rea file to be 0.1 and make certain IFCHAR is F (a few
> lines below);
> > Make certain your dt is positive (param 12)
> > Paul
> > ________________________________________
> > From: nek5000-users-bounces at lists.mcs.anl.gov [
> nek5000-users-bounces at lists.mcs.anl.gov] on behalf of
> nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
> > Sent: Friday, June 02, 2017 10:31 AM
> > Dear Nek Forum, Paul
> >        Yes, I have user defined grid such that the locations of the
> > elements are distributed to lie on the chebyshev grid  at the top and
> > bottom and near the side walls.
> >        Also please tell which param sets the CFL.
> > Thank you
> > Swarandeep
> > On Fri, Jun 2, 2017 at 8:00 PM,  <nek5000-users at lists.mcs.anl.gov>
> wrote:
> >> Dear Swarandeep,
> >> Did you refine your element size at the top and bottom and near the
> side walls?
> >> Please set your CFL to 0.05 in order to get the flow started.
> >> Best,
> >> Paul
> >> Sent: Friday, June 02, 2017 1:04 AM
> >> Hi Nek Forum, Paul
> >>      The top and bottom BC are zero heat flux. Please let me n=know
> >> how to control the CFL. It is 0.5 in the logfile. I am having no
> >> particular difficulty except these corner elements at the junction of
> >> inner cylinder and the top/bottom planes. Is there a better way to
> >> treat edge boundary elements. Also is it possible to have different
> >> order of elements at different locations.
> >> Thank you
> >> Swarandeep
> >> On Fri, Jun 2, 2017 at 12:50 AM,  <nek5000-users at lists.mcs.anl.gov>
> wrote:
> >>> Hi Swarandeep,
> >>> Sorry - I misunderstood.  I guess my question was more about the
> >>> temperature bcs at the bottom and top of the domain?
> >>> In general, however, there should be no difficulty.  What happens
> >>> when you reduce your dt ?
> >>> You need to keep the CFL <  ~0.5 in general.  CFL is printed in the
> logfile,
> >>> grep tep logfile
> >>> and you'll see it  "C= ....."
> >>> Paul
> >>> Sent: Thursday, June 01, 2017 1:57 PM
> >>> Hi NekForum, Paul
> >>>       I intent to have isothermal conditions at the inner and outer
> >>> cylinders. The differential heating is achieved by imposing a
> >>> temperature difference across the two cylinders. I have used T = 1 and
> >>> 0 values for non-dimensional temperature. I think it should be fine.
> >>> Do you see any problem here.
> >>> Thank you
> >>> Swarandeep
> >>> On Thu, Jun 1, 2017 at 11:28 PM,  <nek5000-users at lists.mcs.anl.gov>
> wrote:
> >>>> Hi Swarandeep,
> >>>> Is 0/1 a realistic BC for T ?
> >>>> Best,
> >>>> Paul
> >>>> Sent: Thursday, June 01, 2017 12:53 PM
> >>>>  Hi Nek Forum, Paul
> >>>>        I am having temp = 1 and temp = 0 at the inner and outer
> >>>> boundaries. Gravity is pointing in the -ve z-direction along the axis
> >>>> of the
> >>>>      annulus.  The top and bottom planes have zero heat flux
> conditions.
> >>>>        I have Coriolis force added as a body force.
> >>>>        The Rayleigh number is around 10000. The resolution is 8, 25,
> >>>> 24 elements in the r, phi and z directions respectively with order 9.
> >>>>        My initial condition is very low arbitrary velocity
> >>>> perturbation (~10^(-8)). The time resolution is set to 10^(-5) for
> >>>> param12. The CFL is
> >>>> set to 0.5. Please indicate how to control it.
> >>>>       As you have rightly mentioned, I start the simulation with a
> >>>> very low value of the Rayleigh number and gradually increase it. Yet,
> >>>> the corner values only get large. Other regions of the domain are
> >>>> fine.
> >>>> Thank you
> >>>> Swarandeep
> >>>> On Thu, Jun 1, 2017 at 7:38 PM,  <nek5000-users at lists.mcs.anl.gov>
> wrote:
> >>>>> Hi Swarandeep,
> >>>>> How large is your Rayleigh number and what is your resolution?
> >>>>> What are your thermal bcs?  What are your ICs?
> >>>>> There should be no particular issue with your configuration - but
> you do need to
> >>>>> control spatial and temporal resolution.
> >>>>> For RB, you often have to start at low Ra and/or small dt because
> the nonlinear
> >>>>> response can often drive the velocities to be quite high very
> rapidly before the
> >>>>> CFL constraint kicks in.   RB flows are one of the rare instances
> where I use
> >>>>> variable time step size (param 12 > 0), but even then you have to
> keep the target
> >>>>> CFL quite small until the flow is established.
> >>>>> hth,
> >>>>> Paul
> >>>>> Sent: Thursday, June 01, 2017 7:27 AM
> >>>>> Subject: [Nek5000-users] Corner elements giving large values
> >>>>> Dear Nek forum,
> >>>>>       I am simulating Rayleigh Benard flow in a 3D finite
> cylindrical annulus.
> >>>>>       I am getting spurious large values of velocity at the corner
> regions
> >>>>>       of the annulus i.e. the edges where the inner cylinder joins
> the
> >>>>> top and bottom
> >>>>>       planes. The boundary condition is no-slip and no penetration
> for velocity
> >>>>>       at these edges. Can someone point out a plausible reason.
> >>>>> Thank you
> >>>>> Swarandeep
> >>>>> _______________________________________________
> >>>>> Nek5000-users at lists.mcs.anl.gov
> Message: 2
> Date: Mon, 5 Jun 2017 01:20:04 +0000
> To: "nek5000-users at lists.mcs.anl.gov"
> Message-ID:
>         <mailman.7989.1496625605.2967.nek5000-users at lists.mcs.anl.gov>
> Content-Type: text/plain; charset="us-ascii"
> Swarandeep,
> if you send me your .rea/.usr/SIZE file off-list, I'll take a look.
> Paul
> Sent: Sunday, June 04, 2017 2:42 PM
> Hi Nek Forum, Paul
> time.
> Thank you
> Swarandeep
> > Hi Swarandeep,
> lines below);
> > Paul
> > Thank you
> > Swarandeep
> wrote:
> >> Dear Swarandeep,
> side walls?
> >> Best,
> >> Paul
> >> Hi Nek Forum, Paul
> >> Thank you
> >> Swarandeep
> wrote:
> >>> Hi Swarandeep,
> logfile,
> >>> grep tep logfile
> >>> Paul
> >>> Hi NekForum, Paul
> >>> Thank you
> >>> Swarandeep
> wrote:
> >>>> Hi Swarandeep,
> >>>> Best,
> >>>> Paul
> >>>>  Hi Nek Forum, Paul
> >>>> of the
> conditions.
> >>>> param12. The CFL is
> >>>> fine.
> >>>> Thank you
> >>>> Swarandeep
> wrote:
> >>>>> Hi Swarandeep,
> you do need to
> the nonlinear
> rapidly before the
> where I use
> keep the target
> >>>>> hth,
> >>>>> Paul
> >>>>> Dear Nek forum,
> regions
> the
> >>>>> top and bottom
> for velocity
> >>>>> Thank you
> >>>>> Swarandeep
> End of Nek5000-users Digest, Vol 100, Issue 4
Phil Sakievich
Post Doctoral Research Associate - Mechanical and Aerospace Engineering
Arizona State University - Ira A. Fulton School for Engineering of Matter
Transport and Energy
Tempe, Arizona
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20170605/6101c7c8/attachment-0001.html>
