[Nek5000-users] simulation termination at istep=0 with NaN
Wed Jul 26 12:38:17 CDT 2017
I guess something is wrong with your mesh. Can you post a full log file. Please note that mshconvert is a 3rd party tool.
> On 26 Jul 2017, at 19:26, "nek5000-users at lists.mcs.anl.gov" <nek5000-users at lists.mcs.anl.gov> wrote:
> Hi NEKs,
> I just started working on NEK5000 and am having trouble with my first real simulation (tried both PN/PN and PN/PN-2). I first created a .msh file of simple cylindrical geometry, with velocity-inlet (v), Outlet (O) and surrounding walls (W), in ICEM and used "mshconvert" to get a .rea file. In NEK, the simulation is dying before they actually begin. The error message is as follows:
> Matrix:   0 aa         4       4       4
>   0 aa        Infinity  -4.08542E+02   7.41342E+01   0.00000E+00
>   0 aa    -4.08542E+02   4.65569E+02  -1.31161E+02   0.00000E+00
> Matrix:   0 Aeig       4       4       4
>   0 Aeig           NaN           NaN           NaN           NaN
> Matrix:   0 Deig       1       4       4
>   0 Deig           NaN           NaN           NaN           NaN
>  Error in generalev, info=           3           4           1
> call exitt: dying ...
> I saw an older post regarding a similar problem and that was due to improper boundary conditions. I suspect I may be doing something similar but couldn't find anything until now. The .msh file is fine as I was able to import to "fluent" and run the simulation. Please let me know if you can help in some way. I am posting input files below (please pardon the length of this message):
> ************** FROM .rea FILE*********************
>            0  objects found
>  103   Parameters from file:
>    1      1.00000         p1  DENSITY
>    2     -500.000         p2  VISCOS
>    7      1.00000         p7  RHOCP
>    8      1.00000         p8  CONDUCT
>   11      10000           p11 NSTEPS
>   12      0.10000E-05     p12 DT
>   15      5               p15 IOSTEP
>   18     -20.00000        p18 GRID
>   19     -1.00000         p19 INTYPE
>   20      10.0000         p20 NORDER
>   26      1.00000         p26 COURANT/NTAU
>   27      2.00000         p27 TORDER
>   65      1.00000         p65 #iofiles (eg, 0 or 64); <0 --> sep. dirs
>   66      4.00000         p66 output : <0=ascii, else binary
>   67      4.00000         p67 restart: <0=ascii, else binary
>   93      20.0000          p93 Number of previous pressure solns saved
>   94      3.00000          p94 start projecting velocity after p94 step
>   95      5.00000          p95 start projecting pressure after p95 step
>   99      0.               p99   dealiasing: <0--> off/3--> old/4--> new
>  102      1.00000          p102   Dump out divergence at each time step
>  103     -1.00000          p103   weight of stabilizing filter (.01)
>            13  LOGICAL SWITCHES FOLLOW
>   T     IFFLOW
>   T     IFHEAT
>   T     IFTRAN
>   T F F F F F F F F F F IFNAV & IFADVC (convection in P.S. fields)
>   F F T T T T T T T T T T IFTMSH (IF mesh for this field is T mesh)
>   F     IFAXIS
>   F     IFSTRS
>   F     IFSPLIT
>   F     IFMGRID
>   F     IFMODEL
>   F     IFKEPS
>   F     IFMVBD
>   F     IFCHAR
>  **MESH DATA**
>        22620       3       22620      NEL,NDIM,NELV
>       ELEMENT          1 [    1 ]    GROUP     0
>   0.00000000e+00  0.00000000e+00  0.00000000e+00  0.00000000e+00
>  -7.07106729e-01 -6.82106736e-01 -5.66056759e-01 -5.87769989e-01
>   7.07106833e-01  6.82106832e-01  7.76064003e-01  8.08965813e-01
>   1.02564103e+00  1.02564103e+00  1.02564103e+00  1.02564103e+00
>  -7.07106715e-01 -6.82106722e-01 -5.65372395e-01 -5.87023410e-01
>   7.07106818e-01  6.82106817e-01  7.75121255e-01  8.07937362e-01
>       ELEMENT          2 [    1 ]    GROUP     0
>  -6.82106722e-01 -5.65372395e-01 -5.43721379e-01 -6.57106729e-01
>   6.82106817e-01  7.75121255e-01  7.42305149e-01  6.57106816e-01
>  -6.82106736e-01 -5.66056759e-01 -5.44343529e-01 -6.57106742e-01
>   6.82106832e-01  7.76064003e-01  7.43162193e-01  6.57106831e-01
>   ***** FLUID   BOUNDARY CONDITIONS *****
>  E      1  1 1.4149000e+04 1.0000000e+00 0.0000000e+00 0.0000000e+00 0.0000000e+00
>  E      1  2 2.0000000e+00 1.0000000e+00 0.0000000e+00 0.0000000e+00 0.0000000e+00
>  E      1  3 1.3000000e+01 1.0000000e+00 0.0000000e+00 0.0000000e+00 0.0000000e+00
>  W      1  4 0.0000000e+00 0.0000000e+00 0.0000000e+00 0.0000000e+00 0.0000000e+00
>  v      1  5 0.0000000e+00 0.0000000e+00 0.0000000e+00 0.0000000e+00 0.0000000e+00
>  O  22620  6 0.0000000e+00 0.0000000e+00 0.0000000e+00 0.0000000e+00 0.0000000e+00
> ************** .usr FILE**************
> c All my user functions are empty except userbc to deal with the "v" condition
>       subroutine userbc (ix,iy,iz,iside,ieg)
>       include 'SIZE'
>       include 'TSTEP'
>       include 'INPUT'
>       include 'NEKUSE'
>       ux=0.005
>       uy=0.0
>       uz=0.0
>       return
>       end
> ***********************FIRST FEW LINES OF .map FILE***********
>        22620       24040          14       16384      180960       24040           0
>         3597          14        4574        4561        4560        4562        4575        5164        5162
>         3596        4575        5162        4581        5160        4574        4560        4580        4579
>         3601        4581        5160        4572        5158        4580        4579        4571        4566
>         3603        4572        5158        4570        5182        4571        4566        4569        5181
>         3607        4570        5182        4693        5178        4569        5181        4692        5177
>         3681        4693        5178        4645        5176        4692        5177        4644        5175
>         3683        4645        5176        4649        5174        4644        5175        4648        5173
>         3691        4649        5174        5277        5276        4648        5173        5275        5274
>         3107        5277        5276        4035        4020        5275        5274        4034        4019
>         3106        4035        4020        4033        4026        4034        4019        4032        4024
>         3119        4033        4026        4025        4277        4032        4024        4023        4276
>         3119        4025        4277        4055        4273        4023        4276        4022        4272
>         3599        5164        4561        5172        5171        5162        4560        5170        5169
> Thanks,
> Ajay
> Nek5000-users mailing list
