[Nek5000-users] Setics subroutine in load_fld
Tue Jan 31 01:25:49 CST 2017
Many thanks Tanmoy.
So each time load_fld is called it will load the base
flow variables (I am carrying out computations for incompressible N-S
equations). What if I want to load the perturbations also from a different
file? One way that I see it is to use load_fld for the restart file for
perturbations, copy it in the perturbation variables (vxp, vyp, vzp, prp),
and then again use load_fld for the base flow file. Is there a direct or
better method for this?
Thank you.
Best wishes,
Navrose.
On Monday 30 January 2017 08:15 PM, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Navrose,
> You are right. Two things are important in the load_fld() subroutine.
> The include file 'RESTART' and the routine setics. So everytime a
> load_fld subroutine is being called, the variable values read from the
> current file would be stored in vx(i,j,k,e), vy(i,j,k,e), vz(i,j,k,e),
> pr, t and so on...
> Best Regards,
> Tanmoy
> On Mon, Jan 30, 2017 at 6:04 AM, <nek5000-users at lists.mcs.anl.gov
> <mailto:nek5000-users at lists.mcs.anl.gov>> wrote:
>     Dear Neks,
>       I am relatively new to NEK5000. I am going through some
>     the .usr files that have been used previously in my research
>     group. I notice that in the /userchk/ subroutine, /load_fld /has been
>     called a few times. Upon checking the /load_fld/ function in
>     in the source code, I found that /setics /subroutine is called at the
>     end of /load_fld/ function.
>     Does this mean that each time /load_fld /function is called, the
>     /useric/
>     subroutine in the .usr file is executed? I would like to mention that
>     no restart file is given in the .rea file.
>     Many thanks.
>     Best regards,
>     Navrose.
>     _______________________________________________
>     Nek5000-users mailing list
>     Nek5000-users at lists.mcs.anl.gov
>     <mailto:Nek5000-users at lists.mcs.anl.gov>
>     https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>     <https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users>
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20170131/9a7acf35/attachment.html>
