[Nek5000-users] problem about case turbChannel
Fri Feb 17 02:37:52 CST 2017
Hi, Tanmoy
Thanks! Here are parts of my logfile, and please see the attachment for details. (I didn't change any data for this case)
Starting time loop ...
     DT/DTCFL/DTFS/DTINIT   0.200E-01   0.227-314   0.227-314   0.200E-01
Step      1, t= 2.0000000E-02, DT= 2.0000000E-02, C=  0.521 0.0000E+00 0.0000E+00
filt amp 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0125 0.0500
filt trn 1.0000 1.0000 1.0000 1.0000 1.0000 1.0000 0.9875 0.9500
             Solving for fluid
    1 1.00000E-05         NaN         NaN         NaN       1 Divergence
    2 1.00000E-05         NaN         NaN         NaN       1 Divergence
    3 1.00000E-05         NaN         NaN         NaN       1 Divergence
Best regards!
Hu
-----原始邮件-----
发件人: nek5000-users at lists.mcs.anl.gov
发送时间: 2017年2月14日 星期二
收件人: nek5000-users at lists.mcs.anl.gov
抄送:
主题: Re: [Nek5000-users] problem about case turbChannel
Hi Hu,
Please post a MWE (minimal working example), a logfile / and or a .usr file snippet which your are changing, otherwise it is hard to comment.
Best Regards,
Tanmoy
On Mon, Feb 13, 2017 at 6:42 AM, <nek5000-users at lists.mcs.anl.gov> wrote:
Hi all,
When I tried to do the test "turbChannel", I found value NAN appeared in the process, and after a while the pressure solver detect rank deficiency. I tried almost all the
test case, and found this problem appeared in some other cases. I want to know why and how to accomplish the turbChannel case. Should I change any values in the .usr file?
Best wishes!
Hu
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl.gov
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20170217/27635d2d/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20170217/27635d2d/attachment-0001.obj>
