[Nek5000-users] Update on axisymmetric jet problem
Wed Feb 15 04:58:45 CST 2017
Dear Nek users,
Just to give some more information on the problem I mentioned some days
ago (down below is the original message), here is some more data:
- One of the boundary conditions is periodically oscillating velocity.
- If I remove the axisymmetric conditions, that being:
    · IFHEAT F
    · IFAXIS F
    · IFAZIV F
and simply run it as a 2D example, it seems to run just fine.
- Extremely high values of artificial viscosity (1.0000000E+00     p103)
will make it run longer, but it ends up crashing as well.
- Even when it runs for some seconds (before crashing), log file keeps
giving this kind of error messages:
     19565   100 **ERROR**: Failed in HMHOLTZ: PRES   6.2650E+00
8.4054E+01   1.0000E-06
Any advice will be greatly appreciated.
Thank you in advance.
MViturro
--------Original message---------------
Dear Nek users,
I am doing my master thesis at Technical University of Madrid and I am
using Nek5000 to study an axisymmetric jet.
I have generated the mesh using genbox. Then I have try to run numerical
simulations:
1) 2D
2) Setting: IFAXIS T
3) Setting: IFAXIS T, IFAZIV T (and with IFHEAT T, to plot the azimuthal
velocity.
In all cases my simulation crashes, due to some problems in the boundary
(I have tried with both ON and O BC)
So, I have added artificial viscosity, but the axysimmetric simulation
(case2 2 and 3)  still  crashes:
        3.000000         p99    dealiasing:if <0 disable
        0.0000000E+00     p100 reserved
        1.0000000E+00     p101   No. of additional filter modes
        0.0000000E+00
        1.0000000E-02     p103   weight of stabilizing filter (.01)
Could you give me any recommendation to follow?
MViturro
