[Nek5000-users] Reynolds number setting in the turbChannel example
Fri Dec 22 09:18:09 CST 2017
One additional comment ---
I generally find PnPn to do a better job of LES than PnPn-2, presumably because of the better accuracy for pressure.
Also, interestingly, you can look both at integrated tau_wall and at mean dp/dx for the LES.  Generally, these are in better agreement for PnPn (based on my past experience...)
If you are running constant flow rate (p54/55 nonzero)  then
grep volf logfile > t.t
and plot col 3 of t.t vs col 1 of t.t will show the mean pressure drop, assuming that the body force set in userf is == 0.
I apologize that the volf line does not also show the time, but only the time step number.
(We should correct that...)
Paul
From: Nek5000-users <nek5000-users-bounces at lists.mcs.anl.gov> on behalf of nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
Sent: Friday, December 22, 2017 8:59:52 AM
To: nek5000-users at lists.mcs.anl.gov
Subject: Re: [Nek5000-users] Reynolds number setting in the turbChannel example
the formula mentioned by Paul can be found in Pope's book (Dean's
correlation). Indeed, if Re_tau is off by more than a few percent (say
10) then the quality of the LES is probably not good. Typically, I would
expect a dynamic Smagorinsky model to lead to an underprediction of the
shear.
Philipp
On 2017-12-22 15:19, nek5000-users at lists.mcs.anl.gov wrote:
> Yes -- but presumably if the LES is at all accurate then the mean wall
> shear should be reasonably close to DNS or it has otherwise missed an
> important quantity of interest?
> Paul
> *From:* Nek5000-users <nek5000-users-bounces at lists.mcs.anl.gov> on
> *Sent:* Friday, December 22, 2017 7:40:46 AM
> *To:* nek5000-users at lists.mcs.anl.gov
> *Subject:* Re: [Nek5000-users] Reynolds number setting in the
> turbChannel example
> Re_tau is a simulation result and not known a-priori i.e. the number
> below holds for a DNS but not for an LES.
> -----Original message-----
>> From:nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
>> Sent: Friday 22nd December 2017 14:33
>> Hi Zhenrong,
>> I used 2800 for shear Reynolds number 180 in channel flow and got a good agreement with Kim et al. (1987).
>> Hope it work to you.
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20171222/a9ba6ee9/attachment-0001.html>
