[Nek5000-users] [Re] Viewing Mesh without solution files
Wed Dec 20 19:46:13 CST 2017
If you run with nsteps=0 and fintime=0 then the code dumps the initial conditions without setting up the solvers.
With the initial conditions comes the mesh.
If you turn off all the outputs (ifvo=.false., ifto=.false. etc.) then you would just get the mesh.
Paul
From: Nek5000-users <nek5000-users-bounces at lists.mcs.anl.gov> on behalf of nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
Sent: Wednesday, December 20, 2017 7:40:39 PM
To: nek5000-users at lists.mcs.anl.gov
Subject: [Nek5000-users] [Re] Viewing Mesh without solution files
Dear Amitvikram, I would like to know that also.
What I do is run a simulation and manually finish it after the first time step.
Something that I think may work but (I haven't tried yet) is to make a script to run a simulation and setting everything off, (IFFLOW=false, IFTRANSIENT=false, IFHEAT=false,...etc) so the code will do nothing but deliver a mesh.
It's just an idea.
JP.
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20171221/c4534a4f/attachment-0001.html>
