[Nek5000-users] pipe turbulence
Thu Dec 14 12:14:03 CST 2017
I attached a script that will generate a mesh for a pipe. You can change some of the parameters to generate a finer mesh. The boundary conditions can be changed at the end of the script.
To get a full developed turbulent flow it will depend on the Reynolds number. The files I sent you before should give you a turbulent flow.
Marco
Desc: mkpipe
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20171214/a4cefeef/attachment.obj>
Desc: one2d.rea
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20171214/a4cefeef/attachment-0001.obj>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20171214/a4cefeef/attachment.txt>
