[Nek5000-users] hpts for vorticity field
Tue Dec 5 10:08:40 CST 2017
Dear Sandeep,
Please take a look at hemi.usr in the nekexamples repo.
There is a routine interp_v()  that returns the interpolated
velocity field at a user-prescribed set of points.  You could
easily modify this routine to pass in vorticity and interpolate
that (or any other scalar or vector field).
Please note that you should not duplicate interrogation points
on multiple processors (i.e., each processor should have a
unique set of points, xyz();  one possible configuration is that
MPI rank 0 has a list of points of length n and the other ranks
have a list of length 0;  this approach is valid if the length of the
list is not too large).
hth,
Paul
From: Nek5000-users <nek5000-users-bounces at lists.mcs.anl.gov> on behalf of nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
Sent: Tuesday, December 5, 2017 8:57:20 AM
To: nek5000-users at lists.mcs.anl.gov
Subject: Re: [Nek5000-users] hpts for vorticity field
poor man`s solution: Store your vorticity as an additional scalar field.
-----Original message-----
> From:nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
> Sent: Tuesday 5th December 2017 15:55
> Subject: [Nek5000-users] hpts for vorticity field
> Hello Neks,
> Does anyone knows how to output the vorticity probes using call hpts()
> When I use the function "call hpts()", it outputs only the probes for native arrays like velocity, prssure (and scalar fields, if they exist).
> I compute the vorticity using the function comp_vort3(vort,w1,w2,vx,vy,vz). How can I output the values of the vorticity probes in the flow field using hpts?
> i will be grateful for your answers.
> Thank you in advance.
> Cheers,
> Sandeep
> Nek5000-users mailing list
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20171205/2c8bc7e3/attachment.html>
