[Nek5000-users] Error doing ./maketools for postnek
Mon Aug 28 10:39:21 CDT 2017
Hi all,
Thanks for the replies. I have tried with BIGMEM='true' but it still shows
me the same error. I think the two important parameters that I have to play
with is NELM in 'basics.inc' and MAXPTS in 'basicsp.inc'. Now I wanted to
ask,
Is there a constraint between these 2 parameters? It seems to me you cannot
increase one value as you want, without adjusting the other. Is there a
relation between them for successful compilation?
Previously I had NELM=100 000 and MAXPTS=20 000 000 and it seemed to work
and I didn't change these values, but lesser values might also work.
Thanks a lot,
Saikat
Saikat Mukherjee,
PhD Student,
Paul Research Group - http://www.me.vt.edu/mpaul/
Engineering Science and Mechanics,
Virginia Tech.
On Mon, Aug 28, 2017 at 5:40 AM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Try to recompile with BIGMEM="true" (set in maketools).
> -----Original message-----
> > From:nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
> > Sent: Monday 28th August 2017 11:18
> > To: nek5000-users at lists.mcs.anl.gov
> > Subject: Re: [Nek5000-users] Error doing ./maketools for postnek
> > Hi,
> > Nek uses static allocation and you've increased array sizes. The error
> > you get means that the array is too big to be created. Do you really
> > need so big arrays?
> > Regards
> > Adam
> > On 27/08/17 21:18, nek5000-users at lists.mcs.anl.gov wrote:
> > > Hey Neks,
> > > I have recently installed Nek5000 in a different machine. Now to read
> > > my domain (which is big, 3072 elements), I have changed the NELM in
> > > basics.inc to 100 000 and MAXPTS in basicsp.inc to 20 000 000. Also my
> > > mxpro = 40000 (maximum no of profile points). These parameters were
> > > used by me previously to read same domains successfully, that is why I
> > > am using these.
> > > Now the problem is an issue while compiling maketools. It says -
> > > ./maketools postnek/
> > > Make postnek...
> > > make[1]: Entering directory `/home/msaikat6/Nek5000/tools/postnek'
> > > gfortran -o  /home/msaikat6/Nek5000/bin/postx postnek.o postnek2.o
> > > postnek3.o postnek5.o postnek6.o tsort.o postnek8.o postnek9.o plot.o
> > > getfld.o legend.o userf.o revert.o trap.o animate.o genxyz.o screen.o
> > > g3d.o subs.o xinterface.o locglob.o postnek5a.o blas.o xdriver.o
> > > scrdmp.o coef.o postnek7.o speclib.o mxm.o byte.o ssyev.o iolib.o
> > > -L/usr/lib/X11 -lX11 -lm
> > > postnek.o: In function `fprep_':
> > > postnek.f:(.text+0xf6): relocation truncated to fit: R_X86_64_32S
> > > against symbol `chaar_' defined in COMMON section in postnek.o
> > > postnek.f:(.text+0x133): relocation truncated to fit: R_X86_64_32S
> > > postnek.f:(.text+0x183): relocation truncated to fit: R_X86_64_32S
> > > postnek.f:(.text+0x1c0): relocation truncated to fit: R_X86_64_32S
> > > postnek.f:(.text+0x210): relocation truncated to fit: R_X86_64_32S
> > > postnek.f:(.text+0x24d): relocation truncated to fit: R_X86_64_32S
> > > postnek.f:(.text+0x29d): relocation truncated to fit: R_X86_64_32S
> > > postnek.f:(.text+0x2da): relocation truncated to fit: R_X86_64_32S
> > > postnek.f:(.text+0x32a): relocation truncated to fit: R_X86_64_32S
> > > postnek.f:(.text+0x367): relocation truncated to fit: R_X86_64_32S
> > > postnek.f:(.text+0x3b7): additional relocation overflows omitted from
> the output
> > > collect2: ld returned 1 exit status
> > > make[1]: *** [postx] Error 1
> > > make[1]: Leaving directory `/home/msaikat6/Nek5000/tools/postnek'
> > > make: *** [all] Error 1
> > > I don't understand the problem because I have used the same parameters
> > > previously, successfully. Let me know if you know what the problem is.
> > > Thanks so much.
> > > Saikat
> > _______________________________________________
> > Nek5000-users mailing list
> > Nek5000-users at lists.mcs.anl.gov
> > https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20170828/2e84132f/attachment.html>
