[Nek5000-users] Error doing ./maketools for postnek
Sun Aug 27 14:18:51 CDT 2017
Hey Neks,
I have recently installed Nek5000 in a different machine. Now to read
my domain (which is big, 3072 elements), I have changed the NELM in
basics.inc to 100 000 and MAXPTS in basicsp.inc to 20 000 000. Also my
mxpro = 40000 (maximum no of profile points). These parameters were
used by me previously to read same domains successfully, that is why I
am using these.
Now the problem is an issue while compiling maketools. It says -
./maketools postnek/
Make postnek...
make[1]: Entering directory `/home/msaikat6/Nek5000/tools/postnek'
gfortran -o  /home/msaikat6/Nek5000/bin/postx postnek.o postnek2.o
postnek3.o postnek5.o postnek6.o tsort.o postnek8.o postnek9.o plot.o
getfld.o legend.o userf.o revert.o trap.o animate.o genxyz.o screen.o
g3d.o subs.o xinterface.o locglob.o postnek5a.o blas.o xdriver.o
scrdmp.o coef.o postnek7.o speclib.o mxm.o byte.o ssyev.o iolib.o
-L/usr/lib/X11 -lX11 -lm
postnek.o: In function `fprep_':
postnek.f:(.text+0xf6): relocation truncated to fit: R_X86_64_32S
against symbol `chaar_' defined in COMMON section in postnek.o
postnek.f:(.text+0x133): relocation truncated to fit: R_X86_64_32S
postnek.f:(.text+0x183): relocation truncated to fit: R_X86_64_32S
postnek.f:(.text+0x1c0): relocation truncated to fit: R_X86_64_32S
postnek.f:(.text+0x210): relocation truncated to fit: R_X86_64_32S
postnek.f:(.text+0x24d): relocation truncated to fit: R_X86_64_32S
postnek.f:(.text+0x29d): relocation truncated to fit: R_X86_64_32S
postnek.f:(.text+0x2da): relocation truncated to fit: R_X86_64_32S
postnek.f:(.text+0x32a): relocation truncated to fit: R_X86_64_32S
postnek.f:(.text+0x367): relocation truncated to fit: R_X86_64_32S
postnek.f:(.text+0x3b7): additional relocation overflows omitted from the output
collect2: ld returned 1 exit status
make[1]: *** [postx] Error 1
make[1]: Leaving directory `/home/msaikat6/Nek5000/tools/postnek'
make: *** [all] Error 1
I don't understand the problem because I have used the same parameters
previously, successfully. Let me know if you know what the problem is.
Thanks so much.
Saikat
Saikat Mukherjee,
PhD Student,
Paul Research Group - http://www.me.vt.edu/mpaul/
Engineering Science and Mechanics,
Virginia Tech.
