[Nek5000-users] Linearised Navier Stokes
Fri Aug 18 07:44:03 CDT 2017
Strange. Could you send me your log file? (adam at mech.kth.se)
Regards
Adam
On 18/08/17 14:40, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Adam,
>       Thank you for the continued support. I managed to get the base
> flow and then I used it in a perturbation calculation following the
> dfh_cav case. Peculiarly, I an finding that the basic state is getting
> time stepped and the perturbations are not (in contrast to the dfh_cav
> case). I have used the same .par file from the dfh_cav case and has
> used the follwoing settings:
> [PROBLEMTYPE]
> perturbations = yes
> solveBaseflow = no
> variableProperties = yes
>    Can you please let me know where I am am mistaken.
> Swarandeep
> On Fri, Aug 18, 2017 at 4:52 PM, <nek5000-users at lists.mcs.anl.gov
> <mailto:nek5000-users at lists.mcs.anl.gov>> wrote:
>     Hi,
>     ###.ma2 is the binary version of ###.map file and you need only
>     one of them (it is a new feature). The map (or ma2) is generated
>     by travis during testing by running genmap, so we do not keep it
>     in repository.
>     regards
>     adam
>     On 18/08/17 10:49, nek5000-users at lists.mcs.anl.gov
>     <mailto:nek5000-users at lists.mcs.anl.gov> wrote:
>>     Hi
>>         I could no find the ###.ma2 file for the dfh_cav example.
>>     Hence I suppose I require the ###.box or the ###.map file to
>>     proceed for the base flow. Please correct me if I have misunderstood.
>>     Swarandeep
>>     On Fri, Aug 18, 2017 at 1:03 AM, <nek5000-users at lists.mcs.anl.gov
>>         Hi Swarandeep,
>>         For computing the base flow you can use the same mesh and map
>>         file. What you need to change is 1) the boundary conditions
>>         such that they are valid for the base flow and 2) the flags
>>         that you run a nonlinear instead of a linear case.
>>         As Clio was saying, in that particular case the base flow was
>>         computed using a Newton method. For lower Rayleigh numbers,
>>         you should however be able to just run (nonlinear) DNS to
>>         reach the steady state.
>>         Best regards,
>>         Philipp
>>         On 2017-08-17 20:23, nek5000-users at lists.mcs.anl.gov
>>             Hi Clio and Adam,
>>                     Thanks for the information.
>>               I think in order to compute the base flow I need the
>>             ###.box file as well as a different ###.usr file as I
>>             think the boundary and initial conditions for the ###.usr
>>             file in the short_tests/dfh_cav directory is applicable
>>             for the perturbations only. Please send me the ###.box
>>             and the corresponding ###.usr file applicable for the
>>             base flow for dfh_cav case.
>>             Swarandeep
>>             On Thu, Aug 17, 2017 at 7:03 PM,
>>             <mailto:nek5000-users at lists.mcs.anl.gov>>> wrote:
>>                 Hi Swarandeep,
>>                 The baseflow has been computed with a Newton solver
>>             (which is not
>>                 available in the nek examples). The additional code
>>             had been
>>                 implemented in the version 1040 of nek5000, and there
>>             is no .par
>>                 file for that. However, in general, if your case is
>>             laminar, to
>>                 compute a baseflow, you just need to evaluate the
>>             steady state of
>>                 your nonlinear case. For that, you can use the same
>>             .par file, and
>>                 just change to the nonlinear solver
>>             (perturbationmodes = 0,
>>                 perturbations = no, solveBaseflow = yes).
>>                 The non dimensionalization is based on Hellums and
>>             Churchill (1962).
>>                 The equations are:
>>                 Pr (du/dt + (U*nabla)u + (u*nabla)U) =
>>             1/sqrt(Ra)laplacian(u) -grad
>>                 p + e_g theta
>>                 d theta/dt + (u*nabla)Theta + (U*nabla)theta =
>>                 1/sqrt(Ra)laplacian(theta)
>>                 div(u)=0
>>                 where u, theta are respectively the velocity and
>>             temperature of the
>>                 perturbation, U, Theta the velocity and temperature
>>             of the baseflow.
>>                 You can find more information in the paper
>>             "Saglietti, Clio, et al.
>>                 "Adjoint optimization of natural convection problems:
>>             differentially
>>                 heated cavity." Theoretical and Computational Fluid
>>             Dynamics (2016):
>>                 1-17." on which the example is based.
>>                 Regards,
>>                 clio
>>                 Quoting nek5000-users at lists.mcs.anl.gov
>>             <mailto:nek5000-users at lists.mcs.anl.gov>>:
>>                     Hi Adam,
>>                     Thanks for the clarification. Can you please send
>>             me a sample
>>                     .par file for
>>                     the baseflow for the case of "dfh_cav". Also is
>>             it possible to
>>                     get the
>>                     equations solved for this problem(dfh_cav). I
>>             would like to know
>>                     the way
>>                     that this has been made dimensionless.
>>                     For your kind information I briefly describe my
>>             case which I
>>                     have been used
>>                     to solve with the regular non-linear framework
>>             using older
>>                     versions (.rea
>>                     files). My setup is as follows:
>>                     Geometry is a 3D cylindrical annullus.
>>                     Temperature are fixed at inner and outer cylinders.
>>                     Gravity is acting in -z direction
>>                     There is a back ground rotation which is constant.
>>                     Please let me know if any other info is required.
>>             Thanks for the
>>                     help.
>>                     Swarandeep
>>                     On Thu, Aug 17, 2017 at 1:48 PM,
>>                         Hi Swarandeep,
>>                         Yes. You generate ###.rea in the standard
>>             way. In the old
>>                         version it was
>>                         txt and contained both mesh information and
>>             runtime
>>                         parameter. One could
>>                         split mesh information (###.re2, binary file)
>>             and runtime
>>                         parameters
>>                         (###.rea with negative number of elements or
>>             currently
>>                         ###.par) using
>>                         reatore2 tool. The map file is generated with
>>             genmap (can be
>>                         txt or
>>                         binary). So the procedure is more or less the
>>             same. If you
>>                         have ###.rea
>>                         with mesh you split it and generate ###.re2.
>>             Next you
>>                         generate ###.map with
>>                         genmap and finally ###.par by hand. Be
>>             careful to use tolls
>>                         from the same
>>                         release, as they've been changed
>>             significantly (e.g. binary
>>                         ###.map file).
>>                         Regards
>>                         Adam
>>                         On 16/08/17 18:52,
>>                         Hi Adam,
>>                                   Thank you very much for the help.
>>                                   Does the ###.map, ###.box file  and
>>             from them the
>>                         ###.rea file
>>                         (in the dfh_cav case: the ###.re2 files)  are
>>             created as
>>                         done for the
>>                         earlier versions i.e., by using genbox and
>>             genmap. Please
>>                         clarify.
>>                         Swarandeep
>>                         On Wed, Aug 16, 2017 at 5:35 PM,
>>                             Hi,
>>                             The simplest way would be to look into
>>             existing example
>>                             under
>>             Nek5000/short_test/dfh_cav/
>>                             It is a differentially heated cavity case
>>             and covers
>>                             both direct and
>>                             adjoint linear solver. It is compatible
>>             with the current
>>                             git version and
>>                             uses ###.par file instead of ###.rea.
>>                             Regards
>>                             Adam
>>                             On 11/08/17 11:05,
>>                                 This information might be outdated
>>             (old version) but
>>                                 previously the base
>>                                 flow was read in using the restart
>>             option in the rea
>>                                 file. The disturbance
>>                                 you can read in yourself in userchk.
>>                                 Philipp
>>                                 On 2017-08-11 10:49,
>>                                     Hi Philipp,
>>                                            That was very much
>>             helpful. I have a
>>                                     steady base flow and
>>                                     temperature state. Please let me
>>             know where to
>>                                     provide the base flow.
>>                                     Thank you
>>                                     Swarandeep
>>             _______________________________________________
>>                                     Nek5000-users mailing list
>>             Nek5000-users at lists.mcs.anl.gov
>>             <mailto:Nek5000-users at lists.mcs.anl.gov>
>>             <mailto:Nek5000-users at lists.mcs.anl.gov>>
>>             https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>>             <https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users>
>>             <https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users>>
>>             listNek5000-users at lists.mcs.an
>>             <mailto:listNek5000-users at lists.mcs.an>
>>             <mailto:listNek5000-users at lists.mcs.an>>l.govhttps://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>>             <http://lists.mcs.anl.gov/mailman/listinfo/nek5000-users>
>>             <http://lists.mcs.anl.gov/mailman/listinfo/nek5000-users>>
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20170818/1395bcc1/attachment-0001.html>
