[Nek5000-users] Linearised Navier Stokes
Fri Aug 18 06:22:28 CDT 2017
###.ma2 is the binary version of ###.map file and you need only one of
them (it is a new feature). The map (or ma2) is generated by travis
during testing by running genmap, so we do not keep it in repository.
regards
adam
On 18/08/17 10:49, nek5000-users at lists.mcs.anl.gov wrote:
> Hi
>     I could no find the ###.ma2 file for the dfh_cav example. Hence I
> suppose I require the ###.box or the ###.map file to proceed for the
> base flow. Please correct me if I have misunderstood.
> Swarandeep
> On Fri, Aug 18, 2017 at 1:03 AM, <nek5000-users at lists.mcs.anl.gov
> <mailto:nek5000-users at lists.mcs.anl.gov>> wrote:
>     Hi Swarandeep,
>     For computing the base flow you can use the same mesh and map
>     file. What you need to change is 1) the boundary conditions such
>     that they are valid for the base flow and 2) the flags that you
>     run a nonlinear instead of a linear case.
>     As Clio was saying, in that particular case the base flow was
>     computed using a Newton method. For lower Rayleigh numbers, you
>     should however be able to just run (nonlinear) DNS to reach the
>     steady state.
>     Best regards,
>     Philipp
>     On 2017-08-17 20:23, nek5000-users at lists.mcs.anl.gov
>     <mailto:nek5000-users at lists.mcs.anl.gov> wrote:
>         Hi Clio and Adam,
>                 Thanks for the information.
>           I think in order to compute the base flow I need the ###.box
>         file as well as a different ###.usr file as I think the
>         boundary and initial conditions for the ###.usr file in the
>         short_tests/dfh_cav directory is applicable for the
>         perturbations only. Please send me the ###.box and the
>         corresponding ###.usr file applicable for the base flow for
>         dfh_cav case.
>         Swarandeep
>         On Thu, Aug 17, 2017 at 7:03 PM,
>         <mailto:nek5000-users at lists.mcs.anl.gov>>> wrote:
>             Hi Swarandeep,
>             The baseflow has been computed with a Newton solver (which
>         is not
>             available in the nek examples). The additional code had been
>             implemented in the version 1040 of nek5000, and there is
>         no .par
>             file for that. However, in general, if your case is
>         laminar, to
>             compute a baseflow, you just need to evaluate the steady
>         state of
>             your nonlinear case. For that, you can use the same .par
>         file, and
>             just change to the nonlinear solver (perturbationmodes = 0,
>             perturbations = no, solveBaseflow = yes).
>             The non dimensionalization is based on Hellums and
>         Churchill (1962).
>             The equations are:
>             Pr (du/dt + (U*nabla)u + (u*nabla)U) =
>         1/sqrt(Ra)laplacian(u) -grad
>             p + e_g theta
>             d theta/dt + (u*nabla)Theta + (U*nabla)theta =
>             1/sqrt(Ra)laplacian(theta)
>             div(u)=0
>             where u, theta are respectively the velocity and
>         temperature of the
>             perturbation, U, Theta the velocity and temperature of the
>         baseflow.
>             You can find more information in the paper "Saglietti,
>         Clio, et al.
>             "Adjoint optimization of natural convection problems:
>         differentially
>             heated cavity." Theoretical and Computational Fluid
>         Dynamics (2016):
>             1-17." on which the example is based.
>             Regards,
>             clio
>             Quoting nek5000-users at lists.mcs.anl.gov
>         <mailto:nek5000-users at lists.mcs.anl.gov>>:
>                 Hi Adam,
>                 Thanks for the clarification. Can you please send me a
>         sample
>                 .par file for
>                 the baseflow for the case of "dfh_cav". Also is it
>         possible to
>                 get the
>                 equations solved for this problem(dfh_cav). I would
>         like to know
>                 the way
>                 that this has been made dimensionless.
>                 For your kind information I briefly describe my case
>         which I
>                 have been used
>                 to solve with the regular non-linear framework using older
>                 versions (.rea
>                 files). My setup is as follows:
>                 Geometry is a 3D cylindrical annullus.
>                 Temperature are fixed at inner and outer cylinders.
>                 Gravity is acting in -z direction
>                 There is a back ground rotation which is constant.
>                 Please let me know if any other info is required.
>         Thanks for the
>                 help.
>                 Swarandeep
>                 On Thu, Aug 17, 2017 at 1:48 PM,
>                     Hi Swarandeep,
>                     Yes. You generate ###.rea in the standard way. In
>         the old
>                     version it was
>                     txt and contained both mesh information and runtime
>                     parameter. One could
>                     split mesh information (###.re2, binary file) and
>         runtime
>                     parameters
>                     (###.rea with negative number of elements or currently
>                     ###.par) using
>                     reatore2 tool. The map file is generated with
>         genmap (can be
>                     txt or
>                     binary). So the procedure is more or less the
>         same. If you
>                     have ###.rea
>                     with mesh you split it and generate ###.re2. Next you
>                     generate ###.map with
>                     genmap and finally ###.par by hand. Be careful to
>         use tolls
>                     from the same
>                     release, as they've been changed significantly
>         (e.g. binary
>                     ###.map file).
>                     Regards
>                     Adam
>                     On 16/08/17 18:52, nek5000-users at lists.mcs.anl.gov
>                     Hi Adam,
>                               Thank you very much for the help.
>                               Does the ###.map, ###.box file and from
>         them the
>                     ###.rea file
>                     (in the dfh_cav case: the ###.re2 files) are
>         created as
>                     done for the
>                     earlier versions i.e., by using genbox and genmap.
>         Please
>                     clarify.
>                     Swarandeep
>                     On Wed, Aug 16, 2017 at 5:35 PM,
>                         Hi,
>                         The simplest way would be to look into
>         existing example
>                         under
>                         Nek5000/short_test/dfh_cav/
>                         It is a differentially heated cavity case and
>         covers
>                         both direct and
>                         adjoint linear solver. It is compatible with
>         the current
>                         git version and
>                         uses ###.par file instead of ###.rea.
>                         Regards
>                         Adam
>                         On 11/08/17 11:05,
>                             This information might be outdated (old
>         version) but
>                             previously the base
>                             flow was read in using the restart option
>         in the rea
>                             file. The disturbance
>                             you can read in yourself in userchk.
>                             Philipp
>                             On 2017-08-11 10:49,
>                                 Hi Philipp,
>                                        That was very much helpful. I
>         have a
>                                 steady base flow and
>                                 temperature state. Please let me know
>         where to
>                                 provide the base flow.
>                                 Thank you
>                                 Swarandeep
>         _______________________________________________
>                                 Nek5000-users mailing list
>         Nek5000-users at lists.mcs.anl.gov
>         <mailto:Nek5000-users at lists.mcs.anl.gov>
>         <mailto:Nek5000-users at lists.mcs.anl.gov>>
>         https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>         <https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users>
>         <https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users>>
>         listNek5000-users at lists.mcs.an
>         <mailto:listNek5000-users at lists.mcs.an>
>         <mailto:listNek5000-users at lists.mcs.an>>l.govhttps://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>         <http://lists.mcs.anl.gov/mailman/listinfo/nek5000-users>
>         <http://lists.mcs.anl.gov/mailman/listinfo/nek5000-users>>
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20170818/c6f90c6a/attachment-0001.html>
