[Nek5000-users] Linearised Navier Stokes
Thu Aug 10 09:53:17 CDT 2017
Hi Philipp,
I am using the latest version. Thanks for the help. Until I get the
relevant instructions can you please tell me the following:
 Do I have to do separate runs for base and perturbations or the base
state can be incorporated into perturbation run and a single run be
performed.
Thanks
Swarandeep
On Thu, Aug 10, 2017 at 7:42 PM,  <nek5000-users at lists.mcs.anl.gov> wrote:
> Are you using the latest git version? If so, I think I cannot give you the
> procedure as my knowledge is a bit old. But I can ask Adam next week to give
> you these instructions. Sorry about that.
> But in general, the buoyancy forcing for the perturbations should go into
> userf as it does for the base-flow calculation.
> Or perhaps somebody else could give the guidelines for the new release?
> Philipp
> On 2017-08-10 15:01, nek5000-users at lists.mcs.anl.gov wrote:
>> Hi Philipp,
>>       Can you please outline the procedure to be followed for
>> calculating the perturbed velocity and temperature field based on the
>> following information.
>>      I have a 3d annulus domain with vertical gravity pointing downward
>> and temperature gradient in the radial direction.
>> This leads to a base flow about which I have to linearize the problem.
>> Please let me know how to include the information of the base flow and
>> base temperature gradient into the perturbation calculations.
>> Thank you
>> Swarandeep
>> On Thu, Aug 10, 2017 at 5:51 PM,  <nek5000-users at lists.mcs.anl.gov> wrote:
>>> Hi,
>>> the linearised version is included in the main version of the code. You
>>> activate perturbations by setting NPERT different from zero. The relevant
>>> routines in the code are collected in the file perturb.f.
>>> Hope this helps,
>>> philipp
>>> On 2017-08-10 12:56, nek5000-users at lists.mcs.anl.gov wrote:
>>>> Hi Nek Forum,
>>>>       How to obtain the linearised version of the Nek5000 code. Please
>>>> advice.
>>>> Thanks
>>>>    Swarandeep
>>>> _______________________________________________
>>>> Nek5000-users mailing list
>>>> Nek5000-users at lists.mcs.anl.gov
>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
