[Nek5000-users] Robin boundary condition on velocity
Sat Apr 22 05:35:45 CDT 2017
Hi Francesco,
Robin boundary condition is implemented already for the passive scalar, in the form of Newton cooling boundary condition. You can see how this is implemented in subroutine BCNEUSC. In your case ITYPE=-1 and CB=‘c  ' in the subroutine, and you need to only set ‘HC’ accordingly. We tested this and even our turbulent simulations are stable with Robin BC.
Best regards,
Sudhakar.
> On 21 Apr 2017, at 20:35, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Neks
> I'm trying to implement a slip-length (Robin) as boundary condition for a plane channel flow, namely:
> (u+du/dy)_{wall}=0
> where x and y are the streamwise and wall normal directions respectively.
> Following the latter post:
> http://lists.mcs.anl.gov/pipermail/nek5000-users/2011-April/001313.html <http://lists.mcs.anl.gov/pipermail/nek5000-users/2011-April/001313.html>
> here there's what I came up with:
> c-----------------------------------------------------------------------
>       subroutine userchk
>       include 'SIZE'
>       include 'TOTAL'
>       common /my_DEBUG/ rmodulate
>       common /my_ROBIN/ ROBIN_mask(lx1,ly1,lz1,lelt)
>      $                ,      work1(lx1,ly1,lz1,lelt)
>      $                ,      work2(lx1,ly1,lz1,lelt)
>      $                ,     graduy(lx1,ly1,lz1,lelt)
>       n = nx1*ny1*nz1*nelv
> !!!Build Up MASKS!
>       if (istep.eq.0) then
>         do i=1,n
>           x=xm1(i,1,1,1)
>           y=ym1(i,1,1,1)
>           if(x.gt.3.and.x.lt.4)then
>             ROBIN_mask(i,1,1,1)=1.0
>           else
>             ROBIN_mask(i,1,1,1)=0.0
>           endif
>         enddo
>       endif
> !Compute velocity gradient
>       call rzero(graduy,n)
>       call gradm1(work1,graduy,work2,vx)
>       call dsavg(graduy)
> !      call outpost(work1,graduy,work2,pr,t,'GRD')
> !Da aggiungere l'eventualità del 3D...
>        rmodulate = 0.5*(tanh(0.25*time-10)+1)
>       if (nid.eq.0) write(6,*)"MODULATE", rmodulate,time
>       return
>       end
>       subroutine userbc (ix,iy,iz,iside,eg)
> c     NOTE ::: This subroutine MAY NOT be called by every process
>       include 'SIZE'
>       include 'TOTAL'
>       include 'NEKUSE'
>       integer e, eg
> !Imposing Fancy Boundary Conditions...
> ![Nek5000-users] Robin boundary conditions for the velocity
>       e=gllel(eg) ! global element number to processor-local el. #
>       ux=1*graduy(ix,iy,iz,e)*rmodulate
>       uy=0.0
>       uz=0.0
>       return
>       end
>       subroutine useric (ix,iy,iz,ieg)
>       include 'SIZE'
>       include 'TOTAL'
>       include 'NEKUSE'
>       ux=1.0*y**2
>       uy=0.0
>       uz=0.0
>       temp=0
>       return
>       end
> The code becomes unstable in the gradient computation due to some point-to-point oscillations.
> As you can see I've also tried to use a ramp function in order to make the onset of Robin condition more gentle,
> but at a given "slip-length amplitude" oscillations deteriorates the solution.
> I use ROBIN_mask in order to chose where to have such BC, but it seems that I'm still missing something in computing the velocity gradient GRD.
> By the way, this is my box.BOX file:
> base.rea
> 2                      spatial dimension  ( < 0 --> generate .rea/.re2 pair)
> 1                      number of fields
> #    Example of .box file for channel flow
> #    If nelx (y or z) < 0, then genbox automatically generates the
> #                          grid spacing in the x (y or z) direction
> #                          with a geometric ratio given by "ratio".
> #                          ( ratio=1 implies uniform spacing )
> #    Note that the character bcs _must_ have 3 spaces.
> Box
> -32  -16                                          nelx,nely,nelz for Box
> 0  6.2832 1.                                       x0,x1,gain
> -1  1        1.                                       y0,y1,gain
> P  ,P  ,v  ,v  ,   ,                                bc's  (3 chars each!)
> I was wondering if you might be able to give me some advice.
> Best regards,
> Francesco
> Nek5000-users mailing list
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20170422/42c96cbe/attachment-0001.html>
