[Nek5000-users] proj_ortho error in pipe flow
Sat Apr 8 12:55:36 CDT 2017
Hi Steffen,
which revision of the code are you using? Is the initial field you are
using already turbulent, or are you going through transition? Any
special reason why you have 9 for p94/95?
Philipp
On 2017-04-07 19:54, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Steffen,
> It looks like your solution is hitting a steady-state condition and that the
> projection onto prior solutions is thus projecting in to a set of linearly-dependent
> vectors.
> In principle, the code is supposed to correct for this condition but apparently
> it is not doing so correctly.
> I see you're running at Re > 5000, so presumably you are interested in turbulence,
> rather than laminar steady state.   I would recommend adding a random perturbation
> to the initial condition or, better still, adding something with bound vorticity near the
> walls that will get stretched and bring about a more rapid transition.
> I find that something like the attached works well with channel flow (snap through within
> about 10 convective time units).  I was disappointed that it didn't work as well with pipe
> flow, where I had to go up to Re=40k to get the thing started and then bring it down.
> I assume this has something to do with the lack of linear transition in Hagen-Poiseuille flow.
> If you find a better mechanism to speed transition, I'd be interested to find out about it.
> Best,
> Paul
> From: nek5000-users-bounces at lists.mcs.anl.gov [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
> Sent: Friday, April 07, 2017 10:18 AM
> To: nek5000-users at lists.mcs.anl.gov
> Subject: [Nek5000-users] proj_ortho error in pipe flow
> Dear Nek users,
> I am running a simple pipe flow on a Cray XC40 (Hazel Hen). After 32
> steps, I get this problem (see attachment for complete logfile):
> Step     32, t= 3.2000000E-02, DT= 1.0000000E-03, C=  0.025 3.2660E-01
> 1.0526E-02
>               Solving for fluid
>           32  Project velx           6.6444E-09   2.4759E-09
> 2.6836E+00   8   0
>           32  Hmholtz velx       1   3.9238E-09   6.7918E-07 1.0000E-08
>           32  Project vely           6.8730E-09   2.1046E-09
> 3.2656E+00   8   0
>           32  Hmholtz vely       1   3.6166E-09   5.9974E-07 1.0000E-08
>           32  Project velz           5.2396E-03   2.5121E-06
> 2.0858E+03   8   0
>           32  Hmholtz velz       3   7.6028E-10   9.3795E-04 1.0000E-08
>         32proj_ortho:    2   8 velz   Detect rank deficiency: NaN
> 1.0000E+00
>         32proj_ortho:    1   8 velz   Detect rank deficiency: NaN
> 1.0000E+00
>           32  U-PRES gmres      29   9.9376E-09   5.2213E-04
> 1.0000E-08   8.7926E-03   1.7780E-02
>            32  DNORM, DIVEX  2.704668739973178E-005 9.937641774554489E-009
>        32 0.3200000E-01  1.61568E-01  6.88948E-05  7.85330E-01
> 7.85399E-01 volflow Z
>           32  Fluid done  3.2000E-02  2.4042E-02
> In the next step I get CFL, CTarg! and the simulation exits.
> This problem does neither show up on my local machine nor on another
> smaller cluster. Moreover, when I set either parameter 94 or 95 to 0, I
> do not see this error. It only appears when p94 and p95 are both unequal
> 0. In my case I set them to 9.
> Do you know what might be causing this issue and how to solve it for the
> Cray XC40 system?
> Best Regards
> Steffen
> Nek5000-users mailing list
