[Nek5000-users] Data processing issue
Sat Oct 22 04:59:55 CDT 2016
Hi Neks,
I'm trying to work with Post-processing and before it worked well  but now
I have a strange error on the server:
"Error obtaining unique transport key from ORTE
(orte_precondition_transports not present in
the environment).
  Local host: zeus
It looks like MPI_INIT failed for some reason; your parallel process is
likely to abort.  There are many reasons that a parallel process can
fail during MPI_INIT; some of which are due to configuration or environment
problems.  This failure appears to be an internal failure; here's some
additional information (which may only be relevant to an Open MPI
developer):
  PML add procs failed
  --> Returned "Error" (-1) instead of "Success" (0)
*** An error occurred in MPI_Init
*** on a NULL communicator
*** MPI_ERRORS_ARE_FATAL (processes in this communicator will now abort,
***    and potentially your MPI job)
[zeus:98839] Local abort before MPI_INIT completed successfully; not able
to aggregate error messages, and not able to guarantee that all other
processes were killed!"
I don't understand what about it is.
Thanks to everyone.
Andrey
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20161022/e2b31cf8/attachment.html>
