[Nek5000-users] Problem reading in binary files in Postnek
Tue Oct 11 17:06:10 CDT 2016
Hi everyone,
I am having some problems importing my binary files into postnek. When I do
I have some elements missing and I get this message in the terminal -
postx
window width and/or height > MAX_WINDOWW/H!
-*-Helvetica-Medium-R-Normal--*-*-*-*-*-*-*-*
 NEKTON Version   2.6
Enter Session Name --Default= g40cond_as
 Beginning Session g40cond_as
 renaming SESSION.NAME SESSION.NAME~
 Session name: g40cond_as
 renaming g40cond_as.plt01                         g40cond_as.plt01~
 LTRUNC: string:          28
Tue Oct 11 15:13:33 PDT 2016
 Reading geometry from g40cond_as
                            .rea
XYZ Min,Max:
  -40.0000       40.0000
  -40.0000       40.0000
   0.00000       1.00000
        3072        3017           1  TRYING TO READ BC
        3072        3072           2  TRYING TO READ BC
        3072        3072           3  TRYING TO READ BC
        3072        3072           4  TRYING TO READ BC
        3072        3072           5  TRYING TO READ BC
 LTRUNC: string:          80
 E  E  I  E  E  I  E  E  I  E  E  E  E  I  E  E  E  E  E  E  E  E  E  E  E
 E  E
 LTRUNC: string:          80
 E  E
 LTRUNC: string:          80
 E  E
 this is iffmat: F   6.0000000
 E  E
 E  E
 opening file:          80   E  E  I  E  E  I  E  E  I  E  E  E  E  I  E  E
 this is param(66):   6.0000000
 LTRUNC: string:          80
 E  E
WARNING:  Could not open file.
 E  E
 ** ERROR **  Can't open file g40cond_as.his
Resetting NX to 4.
setwrk:   F  X                         PRESSURE
 ifnew_work: T F                              -33           1
 T  quant: PRESSURE
  derivative:  E  (      64)
 wkmax,delt:PRESSURE               0.0000000       0.0000000       0.0000000
WORK - MAX,MIN:    0.0000        0.0000
wkmin:  0.0000E+00  1.5722E+01  1.5722E+01  7.5000E-01        1
wkmax:  0.0000E+00  1.5722E+01  1.5722E+01  7.5000E-01        1
Volume   of   domain:   0.00000
Integral of function:   0.00000
 calling setquad
 locglob:           1           1       24576
 locglob:           2         395       24576
 locglob:           3         801       24576
 locglob:           1        4005       24576
 locglob:           2        4005       24576
 locglob:           3        4005       24576
done locglob_lexico:     4005     4005    24576
       11044       36864  NEDGE!!
 THIS is nglob       91117
 THIS IS MULT MAX  0.32749921       2.4454923       1.0000000
 196608
 calling setsrfp
 done setsrfp
       11044       36864  NEDGE!!
 THIS is nglob       91117
 196608
setwrk:   T  X                         PRESSURE
ifnew_work: T T PRESSURE                       1           1
 T  quant: PRESSURE
  derivative:  E  (      64)
Volume   of   domain:   5026.56
 1  EXIT
 2  CLEAR
 3  PLOT
 4  SET QUANTITY
 5  SET LOCATION
 6  SET PLOT FORMAT
 7  SET TIME
 8  SET ATTRIBUTE
 9  SET SCREEN
10  SAVE STATE
11  MAKE MOVIE
12  OUTPUT FILE
I believe I am using the latest version. And the parameter 66 is 4. I have
also tried with 6, and it doesn't work. I am grateful for any suggestion.
Saikat.
Saikat Mukherjee,
PhD Student,
Paul Research Group - http://www.me.vt.edu/mpaul/
Engineering Science and Mechanics,
Virginia Tech.
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20161011/b487f7e5/attachment.html>
