[Nek5000-users] Open Boundary condition in NEK user Documentation
Thu Oct 6 06:58:39 CDT 2016
Thank you for a good answer!
Just to clarify, is it in LaTeX written as this:
(\hat{n} \cdot \nabla)(u \cdot \hat{n}) = 0 ?
If the wall normal is in the z-direction, then the open boundary condition for the velocity is:
d/dz u_z = 0?
Best regards,
Johan
From: nek5000-users-bounces at lists.mcs.anl.gov <nek5000-users-bounces at lists.mcs.anl.gov> on behalf of nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
Sent: Thursday, October 6, 2016 12:40 PM
To: nek5000-users at lists.mcs.anl.gov
Subject: Re: [Nek5000-users] Open Boundary condition in NEK user Documentation
Dear Johan,
The outflow boundary condition, 'O  ', is indeed the same as 'I  ' for the thermal problem
since they both enforce grad T . nhat = 0.
However, both also admit thermal flux by advection for cases where U . nhat is > 0, and that is
the intent of outflow --- to allow thermal flux to be carried out.
For velocity, the situation is a bit more delicate.  To leading order, however, 'O   ' imposes
d/dn (U.nhat) = 0 and p=0.    That is, Neumann conditions for the viscous fluxes and Dirichlet
for pressure.
hth,
Paul
From: nek5000-users-bounces at lists.mcs.anl.gov [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
Sent: Thursday, October 06, 2016 4:59 AM
Subject: [Nek5000-users] Open Boundary condition in NEK user Documentation
Dear Neks,
I am trying to understand what is actually meant by an "open boundary" in Nek.
Un the user documentation, eqn (4.5) sais that, for the temperature, it is
grad(T) dot n = 0, where n is the normal to the boundary.
Since the heat flux is q = - grad(T), I would rather interpret this as a zero flux boundary condition.
And indeed, the insulated boundary described by equation (4.6) is identical to the open boundary condition.
Is equation (4.5) a type-O or is the open boundary for the temperature actually the same as an insulated boundary?
Also: Should not the open boundary condition for the "no-stress forumlation" also be given by the same expression as for the "stress-formulation" eqn (4.2)?
Best Regards,
Johan
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20161006/c8a704cc/attachment.html>
