[Nek5000-users] Dirichlet BC for scalars
Mon Oct 3 03:15:29 CDT 2016
I am a new user of Nek, and am learning to possibilities of the program.
I have successfully implemented a lid-driven cavity.
I now want to, in addidtion, solve the problem for a scalar with certain boundary conditions (I did choose the temperature for this).
I use the .box file:
reafile.rea
2
2
Box 1
-20 -20
0.0 1.0 1.0
0.0 1.0 1.0
W  ,W  ,W  ,v  ,
t  ,t  ,O  ,I  ,
Thus: the domains is a 2D 1x1 square where:
* The y = 1 boundary is the "lid" whose velocity can be set in the .usr file (Dirichlet BC)
* The vertical walls also have Dirichlet BC
* The bottom wall is an "open boundary" for the temperature
* The top wall is a n "insulator" for the temperature
Given the .rea file generated with this .box file, I set the initial conditions in useric:
      subroutine useric (ix,iy,iz,ieg)
      include 'SIZE'
      include 'TOTAL'
      include 'NEKUSE'
      ux=0.0
      uy=0.0
      uz=0.0
      temp=0
      return
      end
I set the Dirichlet BC in userbc:
      subroutine userbc (ix,iy,iz,iside,ieg)
c     NOTE ::: This subroutine MAY NOT be called by every process
      include 'SIZE'
      include 'TOTAL'
      include 'NEKUSE'
      ux=1
      uy=0.0
      uz=0.0
      temp=x
      return
      end
I expected this to initialize the velocity and temperature to zero in the entire domain, except for:
* Top boundary has velocity 1 in the x-direction
* The right boundary has temperature 1
But when I visualize the results of the simulation, I find that the temperature is set to "x" in the entire domain, not only at the boundarys that "should be set".
However, the velocity boundary condition works as I expected, and is set only for the "v" boundaries.
What am I doing wrong here? How may I set up dirichlet BC for  the temperature?
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20161003/3f96c18f/attachment.html>
